Removed the throttle body today and it was caked full of carbon deposits,
So removed it and gave it a good clean..i dont have vagcom yet to reset the throttle body,but I have put it back on and taken for a drive and seems to idle fine,choke came on on start up(first start of the day) and drove fine
Not going to tempt fate and take it steady untill it reprogrammes its setting from the ecu
Also had a brief check round the visable pipes(cant see any gashes or holes),Removed my dv and stripped down and cleaned,was full of rubbish as well,Regreased using a very thin Ht grease around the piston,Tighten up all the jubillee clips
Next stop,
Garage smoke test to see where im losing boost pressure,Car felt less boggy and more responsive
and im pleased because its a step closer to decoking the engine
Cleared the fault code 17705 again,Now I shall drive it to work in the morn and then test it when up to proper temp
