Scarletrics :D propa good times haha
How much was that ecs clutch mate?
And is that flywheel really lighter than a G60 one
564 for the kit. Im waiting on mark at awesome getting back to me though due to the delivery delay.
From what I am led to believe the g60 is about 20lbs if u have a lightened g60 its like 16lb. I will stick my lightened g60 and this on on the scales to see.
P.s that boy nae getting back to me. Will let u know if he does
small update
ok clutch is fitted and gearbox back on. will hopefully finish off tonight just need to reconnect all wires transmission cables and fit driveshafts.
pics so far.
part number for chambers:
flywheel fitted:
Clutch fitted and aligned:
Have you got
3000332001 or 3000426001 on the box as the part number?
Its the 3000332001 just checked the prices of the clutch kit by itself and you can get if for a couple of hundred or less :(. If i had know the kit came with a sachs clutch i would of just bought the flywheel for 150ish and bought the sachs sre clutch, so the ecs clutch is slightly over priced i think.
Then again it is rated to 330wheel horse power and 380lb/ft so plenty for what i'm needing.
Yeah will be as it a conversion kit
Dual mass clutch plates dont ned any springs at all (sometimes do) as the dual mass take it all up
Unless ecs replace the springs with uprated ones? I know jag do this with there 2.2D xtype
Guess you cant be sure unless we spoke to ecs or some one at awesome who knows alot about em?
wop car is back on the road a boosting well :). im away down to Norwich with work for a week now so don't get to play with it until next week but i need tracking done real bad.
all strut braces fitted and rear ARB. will be fitting new FMIC in a couple of weeks. Pics to follow when I'm home.
Have the springs got another spring inside as it looks in the pic
(just zoomed in on a laptop)
aye they do bud. the partnumbers you gave don't match the one on the box i will get it for you when im back home. forgot to write it down.
Just read this all and all I can say is epic
cheers bud a lot of hassle but always worth it.
Pics of how it's sitting now
New wheels in t1r's look how close to the brembos forgot to put deter caps on the wheels :(
Crappy pic sorry
