Same boat mate, I'm basically getting exactly the same symptoms but my code is 17963 which is an overboost one! Gonna bite the bullet and get it leak tested shortly, I'v had enough of no power!
Latest update, chaps, I fitted a boost gauge, I'm running 0.5-0.8 bar, still got the code, an feels like a lack of boost at times, dispite being within parameters, it's an odd one :s
It does like to hiss/ whistle (most times) under acceleration, I'm thinking possibly a slight boost leak, and n75 doesn't like it... It sounds like its dumping boost, before the recirc valve gets a chance...
Good idea Richie, certainly a lot cheaper than buying a kit!
Mine is gradually gettg better, (jinxed myself now lol!) generally, I've even fiddling with the split r lately, (full recirc anyway) seems to b helping, I occasionally hit limp mode though, it's a little annoying but last time, I managed over 100 miles and she felt like a different car, then as soon as I say 'I think the split r is set up' (on another thread)I hit limp mode (0.3 bar boost) within 10 miles! Arghh!
Just out of interest, Where did you get your knowledge from lee? Are you a mechanic/ In the motor trade?
Split-R = Leaky DV
Replace it with something which works and does'nt leak and check your other pipes for leaks also..
smoke test it if you know somewhere local who have this kit (I do)
I want to, get it smoke tested but not sure who will do it locally...
Where are you based?
Any decent garage should have one. TC garage near east grinstead have one and looked after my car well. Try local tuners or vag specialists.
you would be surprised how few actually have these.. I was.
Its a must have tool
I am over in Gloucestershire, J13/M5, GL102DG
