That's better ;-)
The brake hose will fit into the back of the Caliper.
Fit with the Nipples at the top (air rises) and I would bleed the inner first then the outer then just check both again for good measure ( that's just me though)
Will do mate thanks
Led rear lights arrived so I smoked them with e-tech tint spray. Put them on tonight and not sure i like them, might have gone too dark with them but Iam trying to go with the stealth theme so maybe darks the way to go ?. Ill see what they look like in the morning and get some pics
started fitting the Brembos. Iam missing the pad retaining clips so not bleed the brakes until i can source the clips
before i started
Old discs and carrier off
old vs new
jet washed it all out while i was there
new discs and dust shields fitted
brembos and badger 5 braided hoses fitted
wheel back on
led rear lights fitted. tinted them with e-tech tint spray for the stealth look. think i went too dark though, might re-do them at some point to a grey\brown tint level. going out to put the rear decal on now
Those brakes look so good!! I'm not a fan of the lights though but that's just me, Have you thought about just tinting a section maybe?
iam sooo undecided on the lights too mate, think it cheapens it. i like my old lights better. i might give them a lighter tint and see what that looks like tbh. iam after a oem tint look to go with the stealth theme, like them pictured
You're right there, it does cheapen it IMO. It's partially why I took mine off because it looks like what a 17 year old would do on his first car.... The LED bit looks good though, You won't be able to get a tint like that will you? That's more tinted plastic, rather than putting a tint on a plastic?
yes its tinted plastic and they dont make anything like that for the mk1 leon, but thats really what iam after. dont think iam gonna achieve what i want from tint spray
joys of having garage means you can bugger about at 3am lol
changed the tint design again, masked off what i wanted to keep and used e-tech tint remover to reveal some red bits, breaks the black down abit and will still go with my black wheels red caliper theme. still not 100% happy but its better
reverted back to my original rear lights. and moved the rear stealth sticker
also fitted new bosch maf and genuine VW coolant temp sensor
