Anyone used Asda's own oil?
Krakum
I used the tescc own oil once and it worked fine at the end of the day there are only 2 companys that drill and refine the oil if im not mistaken
CJS-90
20vT Powahhhh
Sep 30, 2010
444
Clitheroe
Nah there's hundreds of drillers, and thousands of refinery's.
Don't think I'd use it in my LCR but if I had a typical small engined car that was a few years old at that price I'd definitely use it
AshFR
Seat Leon TDi PD150 2005
Mar 10, 2011
385
Shropshire
photobucket.com
Would never use cheap oil in my Leon personally. Or in any other vehicle in fact. Not even halfords own brand, wouldn't even touch it. I only use well known brand and to VW specification.
James D1
Pre-facelift
Aug 2, 2012
255
Essex, Uk
as CJS-90 said im not sure id put it in an lcr, but its probably alright to be fair. i have used varying oil in all of my cars and bikes, never had an issue with any (ive used asda oil in my bike but not car)
Jun 15, 2013
268
Asda don't make oil, Tesco don't make oil, Halfords don't make oil, even VW/Seat don't make oil. I know for a fact that Halfords is made by Comma but as for the rest no idea.
Providing it matches the specification for your engine it will be fine but when I looked at the Asda stuff the other day I spotted a serious flaw. It says on the bottle "VW specification" but it does not list the ones it meets and there are many. It did not list any of the other manufacturers specs that it quoted either. Because of this I would not put it in my Seat.
But, the spec is 5w/30 Fully Synthetic C3 which meets the spec exactly for the Mrs car so if I needed 5 litres I would get some at £14. Better than spending £45 for 4 litres of Shell.
Mikey_Bling
369
Notts
Apparently Comma are doing it for most companies now, as said above they definitely do the Halfrauds stuff and apparently most of your supermarket stuff is Comma too. I've use Comma in my old Astra Turbo and it was fine. I'd happily use it in my LCR, though if I've the choice I tend to steer towards Castrol/ Mobil1 etc.
Everyone knows that if you pay through the nose it's better stuff...right? :blink:
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
Id want to know how the oil performs at low temps like cold starts, when engine wear is at its highest. Im sure they all work well at 90 but given the length of time it takes to warm up during the winter......
Jun 15, 2013
268
That's why oils are multgrades. The 5 means they protect when they are cold and thicker, the 30 means they protect when they are hot and thinner. But VW have used many specs of oil over the years and the Asda container does not detail which it meets. As I said above that means I would not use it.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
Useful info thanks :)
MJ
5,518
15
Manchester
Just for reference, Halfords own brand oil is repackaged Comma oil. http://www.commaoil.com/
You mean comma oil is repackaged and rebranded as "halfords own"
Vw oil is branded as quantum and is blended with Fuchs
The grades for diesel oil is very important especially for the likes of pd engines or those with a DPF. Petrol engines will run well on anything mid ranged but will benefit from higher quality products, especially if they are being driven hard.
RaviR50
2,756
Southampton
Oils have different grades i work in a refinerey and companies like tesco are given the crappier stuff. We blend the oild to the highest standard and then add some crap into it depending on what the company specs up. So if i were you a would go with a high quality fuel like Mobil1...not that im biased to mobil1 cos i work there or anything :p
cupra-barn
It's all about stealth!
Aug 4, 2010
2,109
Worcester
Personally with the oil starvation and blocked pickups that these engines are increasingly suffering from is it worth risking your engine for another £20?
Don't want to upset anyone but search the net and you'll find the proper grade/spec'd oil for your car.
diddles
289
I know what spec oil my car needs, I was just wondering if anyone had any experiences with this oil, I'm going to get some Mobil 1 next month when I service it.
