Why you running a 4bar FPR on a stage 1 map?
Ignore the IDC,s I always saw 100+% when logging on Revo stage 1 and 2.
Lean on the wideband: Any exhaust leaks? Boost leaks? N75 duty? Any fault codes?
On my stage 2 i ran the wideband setup in the second lambda position (decatted), then cable tied the OEM lambda to my anti roll bar still electrically connected. Worked a treat.
Some logs would help.
Hoping for a solution to this on going problem!!
Found some time recently to dig into the problem that is my ibiza at the moment, problem as above!
Now I have checked fuel pressure, seeing 3.5 bar on idle, 5.4 ish on boost. Running 4 bar regulator.
now experiencing it throwing up fuel system too lean code and lambda b1s1 malfunction in circuit.with block 032 showing 25% sometimes! But only so often, and lots of black reek out the back! Sometimes to the point of no longer being able to drive due to misfiring and plumes of black out the back. All the time seeing steady 14.7 give or take a few .1's on the wideband.
Been reading into the lambda code and can point to maf? So health check the maf. I'm getting about 175 g/s peak, 5.5k rpm ish, still seeing 30+ ms Injector times,
Or wiring.. Had a poke around and visual inspection of the localised lambda wiring, seems fine! No obvious breaks, pins on plugs clean.
Do I either..
Buy a new b1 s1 lambda probe, and hope it solves the issue.
Buy injectors, assuming they are not functioning correctly and causing the ecu to demand huge injector loads to run the car.
Or get another ecu, assuming the map is at fault, and demanding huge injector loads possibly caused by a cowboy mapper?
Helps always appreciated folks!
wiring/ECU fault the " lambda b1s1 malfunction in circuit"
Seen it several times on ibizas
not found a cure for it
If your wideband is staying on 14.5 its not working properly
when that faultcode appears it latches the lambda adaption to +25% which is the overfueling. You will see the sensor voltages, likely on both pre and post cat lambdas dropping to near zero volts whilst this fault condition is active
my aem's on overrun go off scale lean as on overrun >2krpm the injectors are switched off. Somethings up with yours, I'm convinced.
I've had reliability issues on my AEM gauges of late and stopped using them on the dyno. (PLx device now)
We rewired the ibiza we had in, direct from lambda to ecu, and swapped ecu's and still could not rid the car of the fault. something else in the shared circuits at play... "somewhere" - we never found it. Disconnected the lambda it was fine.
I would hope that a convert to wideband, as the wiring is different and our loom is what we make up here, would fix something like this, however, without knowing what the actual cause is, there is an element ofand
Does the resistored part of the loom get replaced by your new part?
Sent from my iPad Mini using Tapatalk HD
It's seems to be a common link on cars with this issue.shame it was done before I got it,
It's worth a try removing the resistors I guess... See if it disappears.. They may degrade in the heat above the rocker cover/ turbo area causing something to happen.
I'll get to it searching for an un touched loom!
Bill you reckon your resistors stop this?
it did'nt have any effect on the one we had. we reverted the resistors back to solenoids... but if the damage was done? I dont know. Swapped ecu's at the time and no change either, but I could'nt vouch for that ecu having issue/damage either. My best guess is another component/wiring causing this on a shared power line.... but we could'nt find it at the time. Spent many hours searching, and abandoned it as unecconomic to persue further at the time.
What's normal lambda voltage seen in vagcom?
I'll see if I can dig out the logic info behind the decision side of the ecu, and find what is all linked to the lambda circuit.. And what parameters trigger the b1s1 code, then possibly find out what it thinks is happening then go from there.
We're you seeing high injector times on the other Ibiza's you've seen?
Group A: '031
Voltage Voltage Bin. Bits Bin. Bits
TIME
STAMP V V
0.04 0.24 0.45
0.32 0.24 0.45
0.6 0.24 0.45
0.9 0.24 0.45
1.21 0.24 0.445
1.53 0.24 0.45
1.91 0.24 0.45
2.2 0.24 0.45
2.5 0.235 0.45
2.8 0.24 0.45
3.11 0.235 0.45
3.4 0.24 0.45
3.7 0.24 0.45
4 0.24 0.455
4.31 0.24 0.45
4.6 0.235 0.45
4.9 0.24 0.45
5.2 0.235 0.45
5.51 0.235 0.45
5.8 0.24 0.45
6.1 0.24 0.45
14.21 0.24 0.445
14.5 0.24 0.45
14.8 0.24 0.45
15.1 0.24 0.45
15.4 0.24 0.45
15.69 0.24 0.445
16 0.235 0.45
16.3 0.24 0.45
16.6 0.24 0.445
16.9 0.24 0.45
17.2 0.24 0.445
17.5 0.245 0.45
17.79 0.24 0.445
18.09 0.235 0.45
18.39 0.24 0.445
18.69 0.24 0.445
18.99 0.25 0.445
19.29 0.245 0.445
19.6 0.23 0.45
19.9 0.245 0.445
20.19 0.255 0.45
20.49 0.26 0.445
20.79 0.26 0.45
21.09 0.26 0.445
21.39 0.26 0.445
21.69 0.26 0.445
21.99 0.26 0.445
22.29 0.26 0.445
22.59 0.26 0.45
22.9 0.255 0.445
23.19 0.245 0.445
23.49 0.24 0.45
23.79 0.23 0.445
24.09 0.22 0.445
24.39 0.215 0.445
24.69 0.205 0.445
24.99 0.19 0.445
25.29 0.17 0.445
25.6 0.15 0.44
25.89 0.15 0.44
26.19 0.145 0.445
26.49 0.13 0.445
26.79 0.12 0.445
27.09 0.12 0.445
27.4 0.115 0.445
27.69 0.11 0.445
27.99 0.09 0.44
28.29 0 0.44
28.6 0.035 0.435
28.89 0 0.44
29.19 0 0.435
29.49 0 0.41
29.79 0 0.38
30.09 0 0.38
30.39 0 0.38
30.69 0 0.38
30.99 0 0.38
31.29 0 0.385
31.59 0.005 0.385
31.89 0.01 0.39
32.2 0.035 0.385
32.49 0.74 0.39
32.79 0.77 0.39
33.09 0.775 0.385
33.39 0.785 0.39
33.69 0.785 0.4
33.99 0.79 0.495
34.29 0.71 0.485
34.6 0.345 0.475
34.89 0.11 0.47
35.19 0.07 0.47
35.49 0.055 0.465
35.79 0.05 0.465
36.09 0.045 0.46
36.39 0.04 0.46
36.69 0.04 0.46
36.99 0.045 0.455
37.29 0.04 0.455
37.59 0.04 0.455
37.89 0.045 0.455
38.19 0.04 0.455
38.48 0.04 0.45
38.79 0.035 0.45
39.08 0.01 0.45
39.39 0 0.45
39.69 0 0.44
40 0 0.395
40.3 0 0.385
42 0.075 2803.5 0 -638.4
52.59 0.025 0.46
52.88 0.02 0.455
53.18 0.02 0.46
53.48 0.02 0.455
53.78 0.02 0.455
54.08 0.02 0.455
54.38 0.02 0.455
54.69 0.02 0.455
54.98 0.025 0.455
55.28 0.035 0.455
55.58 0.03 0.46
55.88 0.025 0.46
56.18 0.025 0.455
56.48 0.025 0.455
56.78 0.02 0.455
57.08 0.02 0.46
57.38 0.02 0.455
57.68 0.02 0.455
57.98 0.02 0.455
58.27 0.015 0.455
58.58 0.015 0.455
58.88 0.015 0.455
59.18 0.01 0.45
59.48 0.01 0.455
59.78 0.01 0.455
60.08 0.01 0.455
60.37 0.01 0.455
60.67 0.015 0.45
60.99 0.015 0.45
61.27 0.015 0.45
61.58 0.015 0.45
61.87 0.025 0.455
62.18 0.03 0.455
62.48 0.025 0.455
62.78 0.025 0.455
63.07 0.025 0.455
63.37 0.015 0.45
63.67 0.015 0.45
63.97 0.015 0.45
64.27 0.01 0.455
64.57 0.015 0.45
64.87 0.015 0.45
65.17 0.015 0.45
65.47 0.015 0.45
65.77 0.015 0.45
66.07 0.01 0.45
66.38 0.035 0.455
66.67 0.025 0.455
66.97 0.02 0.455
67.27 0.02 0.45
67.57 0.02 0.45
67.87 0.02 0.45
68.17 0.02 0.45
68.47 0.02 0.45
68.77 0.015 0.45
69.07 0.02 0.45
69.37 0.015 0.45
69.67 0.02 0.45
69.97 0.015 0.45
70.27 0.02 0.45
70.58 0.02 0.445
70.87 0.015 0.445
71.17 0.01 0.45
71.47 0.01 0.445
71.77 0.015 0.445
72.07 0.02 0.445
72.37 0.015 0.445
72.67 0.015 0.45
72.97 0.02 0.445
73.27 0.02 0.445
73.57 0.015 0.445
73.87 0.01 0.445
74.17 0.01 0.445
74.47 0 0.445
74.77 0 0.445
75.07 0 0.43
75.37 0 0.345
75.67 0 0.335
75.97 0 0.335
76.27 0 0.345
76.57 0 0.345
76.87 0.01 0.35
77.17 0.035 0.355
77.47 0.705 0.355
77.77 0.745 0.36
78.07 0.78 0.36
78.37 0.785 0.36
78.67 0.775 0.36
78.97 0.765 0.37
79.27 0.735 0.465
79.57 0.57 0.51
79.87 0.205 0.495
80.17 0.095 0.485
80.46 0.065 0.485
80.77 0.055 0.48
81.06 0.045 0.475
81.37 0.04 0.475
81.67 0.035 0.475
81.97 0.035 0.475
82.27 0.035 0.47
82.57 0.03 0.465
82.87 0.03 0.465
83.16 0.03 0.465
83.46 0.03 0.465
Group A: '031
TIME
STAMP V V
0.3 0.01 0.445
0.57 0.01 0.44
0.87 0.015 0.445
1.17 0.015 0.44
1.47 0.015 0.445
1.77 0.01 0.44
2.07 0.015 0.44
2.37 0.01 0.44
2.67 0.015 0.445
2.97 0.015 0.445
3.27 0.015 0.44
3.57 0.025 0.445
3.87 0.015 0.445
4.17 0.015 0.44
4.47 0.015 0.44
4.77 0.025 0.445
5.07 0.025 0.445
5.37 0.015 0.445
5.67 0.015 0.445
5.97 0.01 0.445
6.27 0.01 0.445
6.57 0.015 0.445
6.87 0.015 0.44
7.17 0.01 0.44
7.47 0.005 0.44
7.77 0.005 0.44
8.07 0.005 0.44
8.37 0 0.44
8.67 0 0.44
8.97 0.035 0.44
9.27 0.025 0.445
9.57 0.02 0.445
9.87 0.02 0.44
10.17 0.015 0.445
10.47 0.015 0.445
10.77 0.015 0.44
11.07 0.015 0.44
11.37 0.01 0.44
11.66 0.005 0.44
11.96 0 0.44
12.26 0 0.435
12.56 0 0.435
12.86 0.01 0.44
13.17 0.015 0.44
13.47 0.015 0.44
13.77 0.015 0.44
14.06 0.015 0.44
14.36 0.015 0.44
14.66 0.035 0.445
14.96 0.025 0.445
15.26 0.03 0.445
15.56 0.025 0.445
15.86 0.015 0.445
16.17 0.015 0.44
16.46 0.015 0.445
16.76 0.01 0.44
17.06 0.02 0.44
17.36 0.02 0.445
17.67 0.02 0.44
17.96 0.025 0.44
18.26 0.02 0.445
18.56 0 0.44
18.86 0 0.44
19.16 0 0.43
19.46 0.02 0.445
19.76 0.015 0.445
20.06 0.02 0.445
20.36 0.02 0.445
20.66 0.025 0.445
20.96 0.03 0.45
21.26 0.01 0.455
21.56 0 0.45
21.86 0 0.45
22.16 0 0.445
22.46 0.03 0.45
22.76 0.03 0.47
23.06 0.025 0.47
23.36 0.015 0.47
23.67 0.005 0.47
23.96 0 0.47
24.26 0 0.47
24.56 0 0.47
24.86 0 0.25
25.16 0 0.035
25.46 0 0.055
25.76 0 0.07
26.06 0 0.085
26.36 0 0.095
26.66 0.025 0.105
26.96 0.055 0.11
27.26 0.55 0.115
27.56 0.67 0.125
27.86 0.72 0.13
28.16 0.75 0.135
28.46 0.76 0.14
28.76 0.765 0.15
29.06 0.75 0.155
29.36 0.745 0.165
29.66 0.725 0.175
29.96 0.72 0.355
30.26 0.715 0.75
30.56 0.71 0.745
30.86 0.7 0.735
31.16 0.675 0.72
31.46 0.665 0.705
31.76 0.67 0.69
32.06 0.63 0.68
32.36 0.76 0.7
32.65 0.755 0.72
32.96 0.715 0.71
33.26 0.705 0.7
33.56 0 0.67
33.86 0 0.595
34.15 0.03 0.55
34.45 0 0.555
34.75 0 0.425
35.05 0.015 0.075
35.35 0.475 0.055
35.65 0.805 0.71
35.96 0.67 0.775
36.26 0.13 0.765
36.56 0.08 0.755
36.85 0.06 0.74
37.15 0.035 0.73
37.45 0.035 0.72
37.76 0.035 0.715
38.05 0.04 0.71
38.36 0.035 0.715
38.65 0.03 0.715
38.95 0.025 0.71
39.25 0.02 0.705
39.55 0.01 0.7
39.85 0.01 0.695
40.15 0.015 0.69
40.45 0.02 0.685
40.75 0.025 0.685
41.05 0.025 0.685
41.35 0.02 0.68
41.65 0.02 0.68
41.95 0.02 0.68
42.25 0.035 0.695
42.55 0.03 0.7
42.85 0.03 0.7
43.15 0.025 0.695
43.45 0.02 0.695
43.75 0.02 0.69
44.05 0.02 0.68
44.35 0.015 0.68
44.65 0.02 0.675
44.95 0.02 0.675
45.25 0.02 0.675
45.55 0.02 0.675
45.85 0.02 0.675
46.15 0 0.67
46.45 0.02 0.645
46.75 0.02 0.655
47.05 0.01 0.655
47.35 0.01 0.65
47.65 0.015 0.65
47.95 0.02 0.655
48.25 0.02 0.655
48.55 0.025 0.66
48.85 0.015 0.655
49.16 0.02 0.66
49.45 0.015 0.655
49.75 0.015 0.645
50.06 0.015 0.65
50.35 0 0.635
50.65 0.02 0.635
50.95 0.01 0.645
51.25 0.01 0.64
51.56 0.01 0.64
51.85 0 0.635
52.15 0 0.63
52.45 0.01 0.63
52.75 0.015 0.635
53.05 0.015 0.645
53.35 0 0.615
53.65 0 0.32
53.95 0 0
54.25 0 0
54.55 0 0
54.84 0 0
55.14 0.02 0
55.44 0.76 0
55.75 0.805 0
56.05 0.81 0.425
56.35 0.8 0.785
56.64 0.685 0.79
56.94 0.16 0.79
57.24 0.08 0.785
57.54 0.055 0.785
57.84 0.04 0.78
58.14 0.035 0.775
58.44 0.035 0.78
58.74 0.035 0.78
59.05 0.035 0.785
59.34 0.03 0.78
59.65 0.025 0.785
59.94 0.025 0.78
60.24 0.02 0.785
60.54 0.02 0.78
60.86 0.025 0.78
61.14 0.02 0.78
61.44 0.02 0.785
61.74 0.02 0.785
62.04 0.02 0.785
62.34 0.02 0.785
62.64 0.02 0.785
62.94 0.015 0.785
63.24 0.005 0.785
63.54 0.01 0.78
63.84 0.01 0.775
64.14 0 0.755
64.44 0 0.7
64.74 0 0.065
65.04 0 0
65.34 0.64 0
65.64 0.68 0.01
65.94 0.67 0.025
66.24 0.645 0.05
66.54 0.625 0.105
66.84 0.645 0.335
67.15 0.655 0.66
67.44 0.67 0.69
67.74 0.675 0.71
68.04 0.67 0.715
68.36 0.67 0.725
68.64 0.66 0.72
68.94 0.655 0.72
69.24 0.64 0.715
69.54 0.635 0.71
69.84 0.635 0.705
70.14 0.64 0.785
70.44 0.125 0.795
70.74 0.065 0.805
71.04 0.05 0.8
71.34 0.035 0.8
71.64 0.03 0.795
