eBay cable and software?
ac2013
49
Guys, I switched on Coming Home/Leaving Home function whilst testing out my cable on my 8P Audi A3, which doesn't have light sensors, and it worked. Lights just come on regardless day or night. There was a separate bit function where I selected 0 for personal rather than selecting 1 for auto (which I assume would mean it uses the light sensor)
Just wondering if you checked for any other options, for your Leon? The new Mk3 platform could be completely different so I could be leading you down completely the wrong path :) But I will try and see if I did a screen shot of the option I changed after enabling CH/LH function.
Please do share if anyone gets to the bottom of this one on their Leon before I do.
AJ
250
I hooked my car up to VCDS and was able to enable the following :D
- Needle Sweep
- Auto Blower Speed
- Alarm Chirp
- Headlight washer, extended activation after 15 wipes
- Tried to extend CH & LH duration to 90secs but it didn't show this in the car setup menu. Still only showed 30secs, will need to revisit this next time.
I was also able to get the Auto Scan info for the Electric Mirrors for the Kerb View Function. Does anybody know which bits of information you would like me to post up so you can compare with your own reading so that you can see whether the mirror issue was fixed with a software update or a firmware update?
AJ
250
I also had a quick look at options for the peeps trying to get LH function to work without having Light sensors.
Seems like you cant do any coding for the Leon as I got this error:
VmkQuptS
So next I went into Adaptions section and found these options
(1)-Comfort illumination-Coming Home Verbaustatus
with possible options: not installed, manual, automatic
UAGIKGN7
(7)-Comfort illumination-Leaving-Home Verbausstatus
with possible options: not enabled, Enabled
w1EGoaP0
(8)-Comfort illumination-Menuesteurerung Leaving-home Freischaltung per BAP
with possible options: not active, active
BIuble70
Not sure if this line of thought is correct but perhaps setting Option 1 to 'Manual' might mean it doesn't use the light sensor as mine is set to 'auto' as I have the light sensor?
Also perhaps check that Option 8 is set to Active?
Just my thoughts :)
Reactions: Andy
labmousee
Geek
Dec 22, 2013
114
Israel
- Needle Sweep
- Auto Blower Speed
- Alarm Chirp
Can you please post your hardware/software version as shown under settings on the multimedia display?
AJ
250
Hi Lab, sure I will get a pic of this during my lunch break later today. Just so that I can get the right info can you tell me exactly where to go please? Is it as simple as going into the Car Menu > then settings or something similar?
nokiauk
524
25
Edinburgh
Could you please post the full auto-scan for this feature so I can compare with mine which was a May 2013 car (an early one).
AJ
250
Lab, I have found the System Info screen you are referring to and have taken a pic for you:
9KUy39hx
Hope that helps you :)
AJ
250
Hi Nokia, no probs. Would you know which part of the log I should copy and paste?
Should I paste the entire Log or everything under the 09: Cent. Elect. Section ?? Cheers
AJ
250
The hardware and software versions are identical to mine (wk45) no drop mirror...
Hmmmm, I guess it must be something to do with the Software/Firmware of the specific module.
Looking at the VCDS instructions to get mirror drop to work changes are made to:
52 - Door Elect, Pass. & 09 - Centr. Elect. modules so I am assuming the answer will be here!
I have just looked at my autoscan log and I dont have a read out for 52 - Door Elect, Pass. :confused: I will have to run another autoscan tonight to get it for you guys.
It looks like my VCDS looped as I have 3 sets of readouts for the following Modules:
01-Engine
03-ABS Brakes
08-Auto HVAC
09-Cent. Elect.
10-Park/Steer Assist
15-Airbags
Anyways, here are my results for 09 - Centr. Elect.:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011333401549
Coding: 0B000A46C24102FB0BA44000B11C07281000000000000000000000000000
Shop #: WSC 00049 770 00129
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7BF5116EF2456DC6C11-802E
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 131028 041 0574
Serial number: 131029220847
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547
Component: RLFS 024 0042
Serial number: Y13M12D04H03M16S01S1
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY131960C4M
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028471113
No fault code found.
nokiauk
524
25
Edinburgh
This is my 09 Cent Elect
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011310800232
Coding: 0B000846C2C102FB0BA44000B11C07081008000000000000000000000000
Shop #: WSC 00049 770 00126
ASAM Dataset: EV_BCMCONTI 010001
VCID: 4683B09AF907E02EEEF-8013
Component: WWS370 130308 041 0574
Serial number: 130312001930
Coding: 0BC5FD
Serial number: Y13M04D26H10M04S32S1
Coding: 00885D
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY130860W3S
Serial number: 00000000000056525823
And 52 Door Elect Pass
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000059181242
Coding: 00100220CC01020000001000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 0109638690A907169BD-8054
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000159664
Coding: 350000
I have the passenger mirror set to dip and it is working
AJ
250
Oh Cool, glad to hear you have got it to work :)
So I don't need to post up my logs for 52 Door Elect Pass?
nokiauk
524
25
Edinburgh
Could be handy as I can't adjust mine even lower and have it return to normal like yours.
ac2013
49
VmkQuptS
UAGIKGN7
w1EGoaP0
BIuble70
Just my thoughts :)
I have tried all these settings this evening and also adjusted setting (9) that read "leaving home Zeit per BAP" which I set to 30 seconds for leaving home.
It has added the option to my menu but has not illuminated any lights on unlocking. It also makes no difference if the light switch is left off or in the main beam position. (obviously have no auto position).
I am beginning to think this might not be possible to enable..
AJ
250
Ahh OK I see what you're saying. I have done a rescan and it has picked up all my modules. So here is my log so you can compare to see if there are any differences:
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000083466461
Coding: 00100220DE01040000001000
VCID: 4385A98ECA35D506C91-8016
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000001134391
Coding: 350000
AJ
250
Sorry to hear that you have tried out the different settings and it doesn't work, it does seem like you might be right :(
nokiauk
524
25
Edinburgh
Hi
There are coding differences between mine (early car) and AJ's (newer car)
This could be to do with other tweaks AJ has made, however I've done a spreadsheet to compare coding of 09 & 52 areas which relate to the wing mirror issues, as mine and AJ's have different features, I don't have issues with it returning, but he can adjust his lower and it will return while mine won't.
Hopefully someone more familiar with coding can assist.
https://docs.google.com/spreadsheet/ccc?key=0AtjlR2wkh670dFpyeE91Y1FqT3Y0RVpPc0ZHVXJCM1E&usp=sharing
wiganlad81
114
9KUy39hx
Slightly off topic but do you all have the "Update Software" option as pictured in the quoted post? I don't.:confused:
ac2013
49
I am still trying to persist with this leaving home setting so I had another look this evening.
I noticed that even though I have made the adaption changes mentioned in the previous post, I notice that if I go into coding and look at byte 0 there are very few ticks against any of the bit numbers.
I am wondering if I need to also enable a bit number in the coding screen, however there are no lists on the screen as to what these bit numbers do.
On my Audi I could use long coding helper to enable these bits and I am sure that Byte 0 bit 5 on older Seats/Audi enabled the leaving home setting.
I am reluctant to tick these boxes as I am unsure of the consequences.
