I honestly do not know man!! I guess i am the luckiest man on earth!!
Sent from my GT-I9195 using Tapatalk
On Sunday I did a Mr Muscle turbo clean followed by an Italian tune up, turbo spools nicely, doesn't spike to anything above 1.6bar (Cupra diesel) and and I'm sure it has a slightly deeper tone to it now too!
Today I've cleaned out my airbox as my cold air feed sucks in a fair bit of debris, and used a spare bit of silicon hose to make a better seal from the cold air feed to the box :)
My '05 LCR with 102K on it is in the garage today for changing OSF wheel bearing, both drop links replacing, cambelt & water pump change, coolant sensor, thermostat, brake fluid change, replacing blown 40A fuse for the cooling fans to see if I still have any in working condition. All that plus hopefully they have time to find an annoying knock from offside rear roughly comes and goes at 30mph.
AlanUK
Do you have to take turbo out for that or do it in place thought about cleaning mine out
I have just got off the phone to cr turbo engineering about organising my hybrid think I am going to go for the stage 3 hybrid
get chatting to AET turbos mate there pretty good as well,dunno bout cr turbos read few things bout them.......as compared to AET,i brought my turbo off them
You do it in situ mate, it's quite fiddly and a bit of a tight squeeze though, even with small Welsh hands!
That centre console arrived today mate, cheers again!
No worrys might have a crack at that at some point although think my turbo leaks oil. Need to do some investigation there
Cleaned and debadged rear end.
[/URL][/IMG]
Then went for something completely different!
Thoughts on this idea?
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Got my Toyosports (Wellycooler) FMIC fitted yesterday by Jonny at Mays Garage near Scarborough on recommendation by googujube, he did a great job and well happy, definitely recommend him!
