eBay cable and software?
keithjeb
187
Hi all
I ahve manage to do some basic changes like the heater control lights and carbon in the instruments, but would like to do the once touch folding of the mirrors on locking, but can't seem to find in the menus .
Can someone please point me in the right direction.
Thanks springerFR
I don't know if it depends on your car or vcds version, but some of the options in the adaptation menu are in English, not German like the guides might be worth manually scanning the list if you are struggling with options.
AJ
250
Hi all
Thanks springerFR
Hi Springer,
Here is the link to the page you need on the German site:
Folding Mirror Link
If the link does not take you directly to the page, just browse down the left and look for Spiegelanklappung radio mode - bizarre translation I know :)
Excalpino
93
Perth, - still in the UK :-)
Hi Taff
Just been reading your input on VCDS cable purchase and have ordered from same supplier. There is still one thing I am not sure about............ Are you saying you can download the Ross_tech software from their site and use that, OR that you use the software that comes with the chinese cable?
AndyN
154
I had to use the software that came with the cable. Tried downloading the real thing and it wouldn't detect the cable.
springerFR
25
South Wales
HI AJ
Thanks for the link , couldn't for the life me find it in that page without your link. Just got back from doing the adaption and works fine.
I am going to see if i can do the cornering light function next chance I get.
Just out of interest does anyone know what the other dislpay option are for,
I have done the carbon bit but on my list it has 4 other options that you can choose.
SpringerFR
metomurti
123
Does anybody know what will happen if we use the aliexpress vagcom cable with the original rosstech software? Will we do any harm to car?
sixysix
346
London
Received my aliexpress 12.12 cable today.
Used original 12.12 software, not the supplied disk, and connected just fine.
Did not have much battery life on the laptop so I just changed a couple of settings which were the Carbon effect, short press on fob to fold in mirrors, and changed the setting for hill hold assist to early.
After doing the hill hold assist, The ABS,ECR, and tyre low symbols all started flashing and thought I had fooked something, but they all went out after a minute so think it was just resetting itself :)
All are working as intended, just need to test the hill hold assist, as I assume "Early" means it will release the brakes earlier so we shall see.
I have three options for the FIS, but only choses option 2 for carbon so can't say what the others are.
Will make a couple more changes tomorrow with the DRL's and that will do me I think :)
metomurti
123
Very good. Would you please share the link that you buy the cable from?
sixysix
346
London
I can do but I checked it earlier today and the link to the page is dead :(
This was the original text of the advert:
2013 newest version VAG 12.12 VAG 12.12.0 Update of VAG 12.10 Support year 2013 for vagcom v12.12.0 with original software
Seller is Alan Lee.
Here is a similar cable. Looks the same as mine and right spec from a different seller, but I can't say that it would be like for like though.
http://www.aliexpress.com/item/2014-newest-version-VAG-12-12-cable-VAG-12-12-0-Update-of-VAG-12-10/1621707423.html
I was surprised as it took 12 days to ship my cable which is pretty quick :)
metomurti
123
Seller is Alan Lee.
Thanks for information. For about 1 month before I bought a cable which must be used with cracked software. I changed some of settings. But i could not change comfort signal number to 5. Then I bought another cable that can be used with original cable. But it has not come yet. And I bought it from the same seller (Allen Lee) too :)
sixysix
346
London
Good stuff, well hopefully it should all work fine :)
I am using an old dell laptop with XP on and all seems ok so far.
AJ
250
HI AJ
SpringerFR
No probs mate, glad you got it working :)
I had 3 options iirc, I chose option 3 as a test and I got a message 'out of range' or something similar after I set it so I put it back to option 2, the carbon fibre option.
metomurti
123
Is there anybody who tried to use the original VCDS software with the Aliexpress cable that works with cracked software?
Will it do any harm to cable or car?
sixysix
346
London
AndyN said that he used the cracked software with his aliexpress cable.
Personally, I would use one or the other, not both just in case it causes any issues.
People have found malware in the cracked software so it could potentially be risky using the cracked software on the car.
Sometimes cracked software does have actual malware in it, but sometimes it can be a false positive from your anti virus software.
Personally, I would not use the cracked software to be on the safe side.
I adjusted the DRL's to turn off with the handbrake applied today and all working fine :)
Now I can turn them off with the engine running if I need to :)
AndyN
154
I tried stock VCDS and it didn't find the cable. I don't have a CD drive, so I downloaded the cracked program after a quick google search. I didn't check it for malware, but I ran it in an isolated Windows XP virtual machine. I have a mac, so had to use virtual box anyway, but I turned off the access to the network adaptor so it couldn't 'get out' even if there was anything on there. There's a detailed guide (earlier in this thread I think) that explains how to do it all for free.
If you have a mac, you have to use virtual box, but if you're on windows it's still a good idea to use a virtual machine that's isolated from your main machine and network connection.
sixysix
346
London
Should be pretty safe that way then if using a cracked version.
I did check the cd that came with my cable and there are a few different version of the vcds software loaded onto it.
The 12.12 version on the cd is exactly the same file size as the one I got from Ross-tech, so it might be the same standard sw on the cd.
I did not try to install from cd so can't say if it unpacks with a crack installed or not though :)
AndyN
154
I don't know, as I say I had to download my version from a web site. It's definitely not stock though, it reminds you to disconnect your internet before plugging in the cable and has pop ups with security codes before you enter them to access each module.
keithjeb
187
You know you can put the option in the display menu?
sixysix
346
London
Really? I looked in the car menu when I got it but never found anything.
I believe that some settings once enabled in vcds, can then be enabled/disabled via the car setting display.
Mine is set so switch in off position = drl's only come on when handbrake is released.
Auto = drl's always on
Sidelights and main remain the same as before.
