What did you and your MK2 do today?
Robbo-K1
203
Hull
A clay bar is basically a piece of clay, that rub along the car's bodywork and is designed to remove all contaminates. Gets all sorts off, tar etc. and leaves an exceptionally smooth finish, similar to polish but really flats the paint back to its originally condition! You have to spray like a lubricant on to make it easy to rub the clay along the paintwork.
I personally have a Meguiars one and really like it and would recommend. However I bet the Autoglym one is just as good. There may be more out there but never had any other experiences.
The idea aswell is to keep turning the piece of clay aswell, trying to keep it as clean as possible if it starts getting mucky :)
Hope this helps...sure a few others can expand on this a little more.
Oct 3, 2012
570
Cambridge
I've found billet hammer the best and you only need to use water as lube not detailing spray
Shawn-C-87
356
Edinburgh
That's the one I got and you only need to use water as a lube!
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
Visit site
The cloth or clay.
I've used a few clays. Tbh if your machining after its not a massively important step as long as you decrease/tar the car.
