Mine move to the left of mirror housing when I select reverse but dont tilt. Have played about with them today lowering them slightly but still don't tilt down.![]()
I'd be interested! Didn't know you could change it!
Hi Andy, here are the instructions to amend the angle of the tilt for the function for UK spec cars:
- Select L position on mirror controller
- Engage reverse gear
- After mirror has finished tilting, change the mirror to the new desired position.
- Disengage reverse gear.
Next time you put it into reverse it will lower to the new position. Give this a try and see if it fixes your issue
Hope that helps mate![]()
1Hi Andy, here are the instructions to amend the angle of the tilt for the function for UK spec cars:
- After mirror has finished tilting/moving, use the electric mirror switch to move the mirror to the new desired position.
The mirror should return to th enormal position when you drive off and go over a certain speed.
Sorry to bring this up again, but I am just trying to set this up on my new Leon ST (collected on Friday from the dealers and lovin it so far...)
I can get the Left Mirror to auto tilt using when the switch is in the L position and have managed to set the position to where I want it.
However when I take the car out of reverse the mirror does not automatically return to the driving position. I have to turn the switch to the centre position for this to happen.
From what I can work out I need to centre the switch once I am done reversing and then turn to L again ready for next time.
Does this sound right or am I doing something wrong?
Hey Chris,
Glad your liking your new car![]()
Also to add on to what Terry wrote, the other scenario the mirrors will go back up is if you leave the switch in L position and then switch the engine off.
