So that puts my approx 1182kg against a mk3 approx 1094kg. How much difference is 88kg likely to make to a 1/4 mile time?
T Sparks does 0-60 in 5 secs, 1/4mile in 13.5 (on rubbish surface). And more power is coming![]()
I've jsut been to Santa Pod today and my best run was 13.935 @ 100.54. I'm pretty pleased with this seen as its only the 2nd time I've been to a drag strip
The best time for a spec similar to mine that i've found on here is 13.16 @ 110.78, however, that was in a Mk3 Cupra which is lighter for starters, and apparently some of the interior was stripped out too.
So how much difference does interior stripping make? Cos I'd like to think that my best time is respectable, given that my car was exactly as I use it on the road, with a boot mat sized piece of 18mm MDF in the boot too!
Parkers suggests that my car weighs 1177kg standard (plus say 5kg for my MDF boot floor? So 1182kg) and a Mk3 Cupra weighs 1119kg (minus prob rear seats, spare wheel maybe 25kg? )
If the car you are reffering to is Iancupra's then you might want to adjust the weight figure slightly.
He was running without any seats other than drivers, and most of the interior stripped out.
I'm happy with my time, so thats all that matters. Perhaps I could shave off another few tenths with a perfect start. I had a good start on my best run, but I feel I could do a bit more Well worth taking the rear seats and spare wheel out.
They make quite a difference, and for the sake of 5 minutes, I'd say its worth it.
Do you have the slips for us to see by any chance?
My tdi fr 130 managed 16.4 1/4 at Santapod last year that was all standard apart from streight through exhaust but I had a slight boost leak.
I've got a 20vt stage 2 had cone filter decat 4bar fuel regulator and revo stage 2 map. Managed 14.09 @ 103.7mph at crail. Backs seats out and spare wheel out. As said already seats make a difference in my opinion.
**** me this thread is 5 years old man
