Adjusted my drivers side side skirt as it had popped out of of the catches at the front. Cleared out a right load of muck too.
Re-painted my front grill surround.
I livened up my front badge by wrapping the background in red vinyl.
This looks good!
Going to do this with mine, was going to spay it but due to stone
Chips I probs vinyl wrap like yours but with a black "S" red background.
How did u get the badge out did you have to take the bumper off or can
U do it with bumper on?
There's a long plastic trim that sits between the bumper and bonnet, it covers a gap and wraps around the bonnet latch. Un-clip this carefully, pull up at one end and use a screwdriver to unlock the clips.
Under the trim you'll see one screw that's holding the badge/grille in place.
You might need some sort of hook to pull the grille out, it's only clipped in once the screw is out.
How did you fix the skirt mate as I have the same issue. A step by step would be really useful.
Sent from my C6903 using Tapatalk
Today's bits..
Today's seen the Ramair induction and Forge 007p
recirc valve fitted, but best of all my documents back
to put my plate on!!!!
Which ramair air filter did you go with mate?
Today I've had service, mot, new front discs and pads, silicone tip and 5 piece boost hose kit installed.
Changed a PCV hose and sorted allll of my boost issues, Oh, then half a tank of Vpower
