Cured my hangover and headache by dropping in a Green Cotton panel filter in which made it much more responsive.
...and then got a new headache from discovering rust emerging from under the black plastic trim on one of the rear doors. Scheisse...
Some scumbag knifed two of my tyres today. What makes it worse is that they'd only been bought within the last month or so. Two practically brand new Eagle F1 Assys.
Changed my cambelt all by myself :) first time id ever done it too
fitted a new engine mount and replaced the rocker cover gasket
Tried the fan speed mod using the guide. Slow speed works a treat on both fans but have no fast speed now . Thinking its the dodgy splice adaptors that you push in. Ive spliced and cut the wrong side of the fan connectors too.surely that wont be the problem?
Tried the fan speed mode using the guide. Slow speed works a treat on both fans but have no fast speed now . Thinking its the dodgy splice adaptors that you push in. Ive spliced and cut the wrong sode of the fan connectors too.surely that wont be the problem?
How do you know you have no fast speed, fast speed only comes on at like 106C, if slow speed is working as it should fast speed should never be needed.
In that case I have a bigger problem... the slow fans only come on if I turn the aircon on. I let it get to 110c before I bottled it and turned it off . No fast fans. On another note the slow fans do come on for a few seconds when I turn engine off. Puzzling...
Replaced my radiator,coolant change, washed and hoovered her and ordered my front splitter and coil overs , me and th car have an up and down relationship but I'm starting to fall back in love with th old girl after our rocky patch.
Very strange, slow speed should come on at 96c,
I know, I clearly haven't wired it up right. Gona pull the splicing apart tomorrow see if had bitten into the black-red cable. I know where my money is...and thats the fast speed wire.
