Played around with a fix for the leaky scuttle, i had the idea some time ago.
On a crude install, it worked quite well. More info soon.
Also dismantled my failed dectane DRLs to repair a snapped wire, had to go through the front and back of the unit. Connected all up to test and had a cracked LED making three others strobe due to my clumsiness. Now have the job to match and replace a single LED.
No fun at all
Still need my scuttle doing,I'll keep an eye out for your info
Finally got round to wrapping my front splitter as didn't want the gloss finish.Hopefully fitting Wed
[/URL][/IMG]
[/URL][/IMG]
Excellent work m8,did think of having mine wrapped
It was a horrible job as I did it with the inlet manifold still on. Modified spanner and all sorts. Then smacked finger with a hammer so hard it split open lol. Was trying to bend a spanner over a kerb and some how missed. Strange as I'm a carpenter and normally pretty good with a hammer.
great im looking forward to doing mine:blink:
Refitted my original mirror covers while I finish off spraying the black ones. Also bought 3 litre's of Millers gearbox oil from Opie oils for £35 delivered. Hopefully I'll be able to change it at the weekend.
Changed Oil + Filter, Fuel Filter ( was never replaced and car is 10 years old !!) , Air filter , new Spark plugs, Cleaned throttle body ( had 2 mm grease on back ). Car runs so much better.
Need Bank 1sensor 1 as it does not give me data on OBD ii so I guess it's gone and car runs rich on idle :rolleyes:
End of the story is that I saved a lot of money as mechanic were puzzled.
Will order one soon.....:lol:
When you cleaned your throttle body what did you do? And did it throw up error codes before?
Well i removed the throttle body but did not disconnected the negative from the battery i cleaned it and put it back. No codes prior but car felt heavy though. I admit that barometric pressure code came up after but after i opened the oil cap while engine running the code disappeared. I drove 50 miles on motorway at 160 km per hour. All good
P.s. that speed was reached only few times :)
Passed my hgv c+e
First attempt!
well done and 1st time as well .. ! I had a go at HGV 2 when I was in Customs and failed twice. I didn't have to pass just needed it for a scanner we had .
I know we moan about Truckers but having done it,I know it certainly ain't easy driving them beasts .;)
Cheers mate, I felt more comfortable in the class 1, but still shat it lol
yes know the feeling . I thought I was going to struggle when during my first few lessons the Instructor told me I nearly took the side off a Renault Clio :D Although I wasn't grinning at the time ,then I got the side of the 7.5tonner caught on some rails near Margate and held all the traffic up ....happy days :)
Just fitted a new oil & coolant cap !
Before
After
Before
After
This was all triggered because my current oil cap was missing a bit and I didn't like it!
Maybe forge window washer bottle next and black coolant tank with viewing section... ☺️
