What did you and your MK2 do today?
Feb 16, 2013
1,103
North Wales
Played around with a fix for the leaky scuttle, i had the idea some time ago.
On a crude install, it worked quite well. More info soon.
Also dismantled my failed dectane DRLs to repair a snapped wire, had to go through the front and back of the unit. Connected all up to test and had a cracked LED making three others strobe due to my clumsiness. Now have the job to match and replace a single LED.
No fun at all
Still need my scuttle doing,I'll keep an eye out for your info
Feb 16, 2013
1,103
North Wales
Finally got round to wrapping my front splitter as didn't want the gloss finish.Hopefully fitting Wed
[/URL][/IMG]
[/URL][/IMG]
Excellent work m8,did think of having mine wrapped
Apr 1, 2014
865
'up anley duck'
It was a horrible job as I did it with the inlet manifold still on. Modified spanner and all sorts. Then smacked finger with a hammer so hard it split open lol. Was trying to bend a spanner over a kerb and some how missed. Strange as I'm a carpenter and normally pretty good with a hammer.
great im looking forward to doing mine:blink:
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,873
7
Middlesbrough
Refitted my original mirror covers while I finish off spraying the black ones. Also bought 3 litre's of Millers gearbox oil from Opie oils for £35 delivered. Hopefully I'll be able to change it at the weekend.
suditaliano
39
Changed Oil + Filter, Fuel Filter ( was never replaced and car is 10 years old !!) , Air filter , new Spark plugs, Cleaned throttle body ( had 2 mm grease on back ). Car runs so much better.
Need Bank 1sensor 1 as it does not give me data on OBD ii so I guess it's gone and car runs rich on idle :rolleyes:
End of the story is that I saved a lot of money as mechanic were puzzled.
Will order one soon.....:lol:
Jan 3, 2014
593
When you cleaned your throttle body what did you do? And did it throw up error codes before?
suditaliano
39
Well i removed the throttle body but did not disconnected the negative from the battery i cleaned it and put it back. No codes prior but car felt heavy though. I admit that barometric pressure code came up after but after i opened the oil cap while engine running the code disappeared. I drove 50 miles on motorway at 160 km per hour. All good
suditaliano
39
P.s. that speed was reached only few times :)
colsy
1,349
569
Dover
Passed my hgv c+e
First attempt!
well done and 1st time as well .. ! I had a go at HGV 2 when I was in Customs and failed twice. I didn't have to pass just needed it for a scanner we had .
I know we moan about Truckers but having done it,I know it certainly ain't easy driving them beasts .;)
bigbadjay
1,670
26
North Manchester
Cheers mate, I felt more comfortable in the class 1, but still shat it lol
colsy
1,349
569
Dover
yes know the feeling . I thought I was going to struggle when during my first few lessons the Instructor told me I nearly took the side off a Renault Clio :D Although I wasn't grinning at the time ,then I got the side of the 7.5tonner caught on some rails near Margate and held all the traffic up ....happy days :)
Stylance
Stylance
Apr 6, 2011
647
Ashford kent
Just fitted a new oil & coolant cap !
Before
After
Before
After
This was all triggered because my current oil cap was missing a bit and I didn't like it!
Maybe forge window washer bottle next and black coolant tank with viewing section... ☺️
