GR33NY
53
Market Harborough
Evening all , my seat cupra r has been a dream to me and have never had any problems at all but I get into it this morning to head off to work and it just turns over and over but won't start. Now the EPC fault light has come up , I've had it hooked up and no fault codes , checked relays. Fuses all ok ...
Towed it tonight and bumped it and ran fine once goin but soon as u turn off its back again. :confused:
I have noticed u don't hear the whining noise when u open the door or enter key into the ignition asif it's priming the fuel anymore but can't seem to find Wht it is.
Any ideas or similar problems ?????
Check the fuse for the in-tank fuel pump or lift the back seat base and pull the connector of the top of the pump and check for 12V at the connector with a multi meter. If the fuse is ok and you have power at the connector, the pump is dead. Like anything electrical, they tend to fail when it gets a bit colder. If you have no power at the connector, your fuel pump relay is probably goosed.
Could be your crankshaft position sensor, Iv had a similar problem like this, your EPC light relates to the electronic accerator pedal, but I reckon that's come on because it's just winding over an over when you try to start it,,
where abouts you located,, Iv got a couple of spares, you can have 1 if you want,,
There about £30 form Euro car parts but your best buying genuine with stuff like sensors
But Id follow Ross's instructions 1st
if your bumping it and its going fine then it rules out fuel pump, also if the car isnt detecting the drivers door opening it may not be priming the pump, get some wd40 into the door catch to see if anything has frozen up.
the epc light came on mine when my crank position sensor went tits up. basically the same symptoms as you, the car would turn over( but eventually start)
Cheers for the quick reply fellas. I'm near Leicester lowry. But I'll be doin the checks Ross has mentioned thn the sensor , glad it's summat simple
Failed Crank Position sensor inhibits spark, not fuel. You should still hear the fuel pump priming.
http://www.seatcupra.net/forums/showthread.php?t=337049
I know what your saying Ross, it's just Iv had a lc180 in the workshop, with same symptoms, with no fault codes, just wouldn't start, no fuel pump priming and no spark aswell
I replaced the crank sensor, turned ignition on then the fuel pump started priming and it fired up 1st time, this was well over a year ago and it never came back
Reactions: GR33NY
Stranger things have happened mate and very little surprises me with the fuel/ignition system on the Mk4 platform. It could well be the crank sensor but it's free to check the pump voltage first. No sense chucking good money after bad.
Checked thm all and now bought a crank sensor but can't find where it is on the car. ☺️
Any body got any pics of where I will find where it's located or any help at all. ??
Just got in from fitting it , pissing down with rain so I fitted from top but couldn't see a thing lol.
Turned key and she back to life
Thanks for all ur help my friends.
Have you recently had the scuttle panel off???
Could be a loose connection at the ecu, there's 2x muti-plugs that go in the ecu, Iv seen them work loose,, it's worth a shot, you need to pop your wiper arms off, remove the seal and pollen filter and then the scuttle panel will lift off, you will then see the ecu, give the plugs a wiggle then give it a go,,
If that doesn't work, you must have a dodgy connection,dodgy Earth or even a broken/corroded wire,
