egr
cleaned out egr yesterday that was a lovely job. at least the gate wont stick shut now.
and I can drive it. what a dirty job that was. on the upside I can now see into the inlet so
she should be able to breath properly now.
now to find out how to turn the egr down to as low as possible.
Had my turbo replaced with a brand new one last Thursday, been without internet for a while thus not being on here! :O
--Lee
Fitted new climate control unit, ran hose through the bulkhead for my boost gauge and sealed all up! (hopefully) fit gauges and pillar pod tomorrow!
Hi mate just wondered what gauges and pillar pods you have to instal and pics? I'm looking at getting a nomad single pillar pod and 52mm r spec stepper motor psi boost gauge. Would be good to get your opinion of yours.
My Lc's been running like a bag of shite the past couple of days, lumpy idle cutting out the works so today I changed the maf and got some new Bosch 2.0 tfsi coilpacks and adapters, fitted em and took it for a run. The idles now smooth ,but still cut out at two sets of traffic lights[:@] so next it'll be to clean the throttle body and sensor and see if that cures that.
this but now it's smoking.... Petrol btw
Stripped the interior fully, ordered solid engine mounts, bucket seat subframes, new steering wheel and snap off boss!! Buying a roll cage later too!
Took the **** universal cone filter off and re fitted the standard (drilled) air box and filter :) but just remembered I forgot to re attach the sai pipe doh! Lol
Did some cooking.
Dunno why it turned out so dark.... Little disappointed... But better then it was !
[url=https://flic.kr/p/r1htMa]WhanAB spacer & shield by whanabiv, on Flickr[/URL]
[url=https://flic.kr/p/rhGXa8]WhanAB spacer & shield by whanabiv, on Flickr[/URL]
[url=https://flic.kr/p/rfpMuo]WhanAB spacer & shield by whanabiv, on Flickr[/URL]
[url=https://flic.kr/p/rhyVeB]WhanAB spacer & shield by whanabiv, on Flickr[/URL]
there is a 3/16 inch spacer between valve cover and the polished/mirrored aluminium shield and the wires are also protected by Heat Shield high heat wrap has a open air flow from right to left.............
We also used Heat Shield high heat wrap on the Timing Chain Cover as it was getting some much heat from the upgraded turbo it was melting... Just an FYI on that.......
We are going to start selling the spacer kit for the valve cover.... What do you think of it ?????
it is held down with the existing bolt for the ground
bought some new boots for the front. Yokohamas - so at least they'll be matching front to back
