Modifications
andychef1234
62
Aberdeen
Boot opening exeo st
Hi guys I have a exeo st and looking to do the automatic boot open upgrade. Anybody know if you can just replace the gas struts and add in the springs.
If so anybody know the best place to get them?
Any advice would be great
cheers in advance :D
flash061
95
Lisburn - Northern Ireland.
Spoilers?
Hi guys,
Just wondering about Spoilers for the Exeos? I want the boot lip spoiler, where is the best place to get one? Also I've seen an RS4 flying about with a rear top window spoiler too? Hoping these aren't only Audi parts, although saying that, there is nothing listed for them on any seat accessory site. What sort of splitters are people fitting too? I have a 2011 Sport Tech and want to spruce it up a touch I suppose. I seen an Octavia VRS with a cracking looking splitter on it, not sure if a Skoda genuine or just an aftermarket yolk.
Any info would be ticket, ta folks.
J
richdot
123
ABH0 103 928 LHS my local TPS doesn't reconise this part number has everyone had joy with this part number then?
richdot
123
Got all the covers ordered and paid for cost more than I expected £85.xx for the 4 covers and rubber gasket.
richdot
123
8H0 103 928 and 8E0 103 927 D Doesnt fit to my Seat exeo 2.0 tdi 143 the 8E0 103 927 D that fits near the coolant expansion and screen wash resivour there is a pipe underneeth the little over flow pipe which must be intercooler pipe thats in the way and wont fit around. 8H0 103 928 doesnt fit, fits in the gap but won't push down as braided hoses and clips coming from the fuel filter housing are in the way.
Fitted the scuttle panel and left with a gap on the top left looks like another cover should go there?
Anyone any ideas
ajf3011
82
Burnham
Anyone any ideas
Unfortunately you've got the wrong part number for the screenwash bottle cover to fit the TDI, you need 8E0 103 927 F.
For the top left over the ECU there is a cover that can be modified to fit, part number and pics of mine on this thread http://www.seatcupra.net/forums/showthread.php?t=415540&page=2. Costs approx £23.
Not fitted 8H0 103 928 myself, but Seafar99 has and posted a brief description of how he modified it to fit on the thread I linked to above.
richdot
123
Thanks for the reply ill order that other cover then thanks, how did you fit the ecu cover then as that will finish the scuttle panel off then as at the moment it looks half done because of that gap.
Yes I might not bother with that air con cover might just send it back to be honest.
ajf3011
82
Burnham
ECU cover just needs to be trimmed down so that it sits flush over the existing ECU housing, it's pretty obvious what you need to cut off when you see the part. Then just glued a couple of sheets of packaging foam (like this http://www.ebay.co.uk/itm/261829652520?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT) inside to pack it out.
cbates1990
78
There the Exeo is based on the Audi A4 I was actually wondering what modifications and/or original Audi parts have been added to the car by the Exeo owners here.
Here's my list of modifications so far:
1. LED interior lighting
Bought this recently from BlueCars.net in France. The bulbs for the reading light above the rear seat were of the wrong type but BlueCars sent me new ones.​
2. Ambient LED light front
Part needed: 8E0919063A (GBP 11,00)
Tools needed: Torx screwdriver no. 15 and a drill.
Description (german): http://a4.scirocco-5v-turbo.de/beschreibungen/innenleuchte/innenleuchte.html
3. Grocery bag hooks in trunk
See here.
Parts needed for 1 hook:
1x Hook : 6Y5867615
2x Screw: N10656902
2x Nut: N90156103
Tools needed: Torx screwdriver no. 25
You can install 2 hooks in the trunk. These hooks have a spring so they fold up when there's no weight on them.
Description (spanish): http://clubseatexeo.com/foro/index.php?topic=2228.0
4. RS4 pedals
The original Audi RS4 pedals.​
5. Plastic covers engine compartment
Part Number / Description / Price
1. A8E2 819 422 AO 1C - Battery Cover £5.17
2. A8E2 819 447 01 C - Scuttle cover £12.60
3. ABH0 103 928 LHS - Air con Cover £13.42
4. A8E0 103 927 D0 1C - Fluid bottles cover £13.42
Items 1 and 2 are a must have. Read here why you need these.
6. Rubber gasket around engine compartment under bonnet
Part no.: 8E0823731B (GBP 15,00)
This rubber seal will prevent dust/sand entering the engine compartment.​
7. Chrome Fog Light Trims
Part numbers (VAG):
Left: 8T08531012ZZ
Right: 8T08531022ZZ
Price: less than GBP 10,00 each.
See here on clubseatexeo.com: http://clubseatexeo.com/foro/index.php?topic=3696.0
See also here: http://www.seatcupra.net/forums/showpost.php?p=3562814&postcount=53
index.php
8. Audi RS4 (B7) Rear Anti-roll Bar
Part Number / Description (qty) / Price (to follow)
8E0511409AL - Rear Stabilizer Bar
8E0511327B - bushes x2
8E0511439 - clips x2
N10127706 - bolts x 4
DIY install guide, courtesy of Audizine:
http://www.audizine.com/forum/showthread.php/225821-RS4-Rear-Sway-Bar-Install
More info:
http://www.seatcupra.net/forums/showthread.php?t=242598&highlight=rs4
9. Auto Opening of Boot
1x Hinge, right: 8E5827301H (GBP 26,--) [pos. 5]
1x Hinge, left: 8E5827302H (GBP 26,--) [pos. 5]
1x Cover, right: 8E5971822C (GBP 2,65) [pos. 9]
1x Cover, left: 8E5971821C (GBP 2,65) [pos. 9]
2x Spring: 4F5827665A (GBP 13,-- each) [pos. 26]
2x Gas spring: 8E5827552K (GBP 21,-- each) [pos. 22]
(all above part numbers are from Audi, see drawing below for position reference)
See this YouTube move: http://www.youtube.com/watch?v=oEVGrkjJWCQ
See post #37
10. Ambient LED light rear
Lamp unit:
1x 8E0 947 111 A 9NQ (silver), or
1x 8E0 947 111 A 8C1 (torrone beige)
Ambient LED unit:
1x 8E0 919 063 A
See for more information here: Link
11. 12V socket cap with chrome ring
Part no.: 4L0 919 311 (less than GBP 5,00)
Can anyone point me in the right direction? Mod 5 looks like it's based on the left hand drive version and I've got the right hand drive, I've just been out to check the oil levels on the car noticed the battery is open to all the elements so I would like to do this mod asap.
cbates1990
78
Just bought this for the car, can't wait to get it on there.
Iansexeotech
9
Does anyone have a list of part numbers for the uk in ref to the above panel, bottle covers ( passenger side of the engine bay ) and the bonnet seal as the first set are old now and look to be from the lhd car.
jambo1979
Would like to know the same myself plus the seal as there seems to be various different part numbers referenced both here and elsewhere online !
Dicko90
78
Struggling to find this part. 8E2 819 447 01 C seems to be for smaller scuttle cover, not the whole width cover.
That’s the part number which is on my Audi invoice when I bought my covers and it’s looks just like the one in the picture.
The other part numbers on my invoice:
8E2 819 422 A0 1C. Battery cover
8E0 823 731 B Engine bay rubber gasket
Bowen
260
10
on daveibiza's drive.
Cheers mate. Ebay turns up the pollen filter with that part number. Off to TPS I go.
Don't suppose you have the total price on that invoice do you?
Dicko90
78
There not cheap parts considering it’s just plastic and rubber :) from the top of my head it was around the £70 mark but I did buy them direct from Audi
Fnesslee
35
I've just fitted some bigger calipers off an
A4 tfsi rebuilt them and painted them up chuffed with them
