The procedure in the new Ibiza is the following:
Turn on the recirculation.
Then press simultaneously the five central buttons of the climatronic: Auto, Econ and the three arrows. You can scroll through 52 codes using the temp knob. However I have no idea what each code stands for!!
Yes, I've seen this before - I think you can do various tricks on most VAG group cars with Climatronic, but can't remember much about it or how you do it.
Do a search - it's been discussed somewhere before, try searching on "climatronic" that should point you in the right direction....
I have a strange question for you guys....is it normal that when i put the car in 'reverse' while the aircon/climate control is on, the fan's speed up.....then one i put the car into 'first' gear the fan's reduce speed.
would my climate control need a reset of do i have issues with the ECU?
