Here we go, gives you an idea of how God the cutoff line is and how bright the lights are. These won't dazzle oncoming drivers! All my conversions have this clean cutoff line!
Wow Rob,
Those look great, great talent you have,
Just wondering do you do the Audi style for Mk4 Toledo?
Ohright that is a shame
Keep up the work really makes a difference to a car
Sent from my SM-G920F using Tapatalk
Hey Rob I was wondering if you might know if these are legal and will pass an MOT and possibly the legislation on head lights as I've heard alsorts like I cannot upgrade my standard lights as I have no headlight washers unless I retrofit them too cheers.
Basically the MOT legislation has a number of grey areas however as long as your lights don't dazzle/have the correct beam pattern then you will be fine. My headlights have the correct projectors with a cutoff line which won't dazzle so no problems there.
There is also confusion with washers and self levelling. In simplistic terms, if it's on your car then it needs to work, if not then they can't rest it and ultimately fail it. I'm sure you will remember the spare tyre issue...if you have a spare tyre it must be legal, however if it's not there then they can't test it and thus can't fail your MOT.
Hopefully this helps answer your queries. And if it's any use for those out there, the wife's car us a set of H7R Hids fitted and they passed the mot without any issues.
Rob
Hi there sir !! I've been guided to yourself in regards of some headlamps, basically i have an 2012 Exeo saloon, and i have the worse possible headlights which are the reflectors... I really dont like them, I would love the Exeo Xenon with DRLS but i looked everywhere and no luck. Would you be the man to talk to perhaps ?!? :) Take care
Hello buddy, yes I would be the one to speak to however the problem is getting hold of aftermarket lights for your 2012 Exeo as they aren't readily available apart from Valeo which are currently quite expensive and a pain to open.
Right okay, do you have anything in mind for now or is it a no go for quite some time, i tried to message you but i can't find a private message button haha, I am new on forum so might not have the power just yet maybe?!
Thank you :)
can someone point me to the 'for sale' section. i may need some parts others are getting rid off.
Thanks! oh btw great work with the headlights Rob, after my epic fail in the oven i let that dream go lol :D
