Where's the battery box from mate, i like that
I could be wrong but I think you have to go to Volkswagen directly. I'm sure someone will correct me if I'm wrong!
Just looks beautiful man and keeps on getting more and more beautiful!
It's going to be unreal when she's stage 2+!
What's been the hardest or most awkward/difficult mod you've done yourself so far?
--Lee
Still looking good Craig, it amazes me just how many things you can update on a car, can't wait to see what's coming next.
Will
Engine bay looks gleaming mate, I need to do the filler neck mod myselfwhere did you get the R8 cap from? Car looks very well kept!!
Climate is a massive improvement, I've got a standard dacelift MPs stereo here if anyone's Intrested
It was off eBay mate just had a look and it says they only fit up to a 2010
If you search mk2 Leon number plate lamps you should be able find ones that fit![]()
Lovely car mate, very carefully looked after and maintained, full of tastefull mods.
I see you've good new injector seals, is it recommended to change the seals when the manifold is off or just good practice? Just I've got APR rfd and Rs4 fprv waiting for fitting and while the manifold is off I'm going to get the valves cleaned.
Ok cheers, can you just get the injector seals from tps? Do you have a part number? I'm going to get some and change them if needed when my manifold is off.
Thanks for the part numbers mate I'll check the injector number and get the seals order.
