Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
So the list as of lunchtime of things that's need doing - in no particular order
door locks repairing
rear calipers replacing
hand brake cables replacing
discs all round replacing
front calipers refurbishing
3 new tyres
engine service
redo catch tank hoses
what have I done to my car today - nothing but I've made a list.
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
3 new tyres
engine service
Let me no how you get on with the hand break cables as I need to do mine soon, I tryed in the scrapies to see how to do it but once u get it of the caliper there's a piece of metal tubbing I couldn't get off.
Bigjohn84
May 5, 2015
2,330
Just installed a new collant bottle and flushed the system also put fresh coolant in looks great
AmD Stage 1 Map, Forge 007 DV, RamAir Induction Kit, Oversized SFS Tip GT80 Milltek Sports Cat Back, 40mm Springs All Round
Bigjohn84
May 5, 2015
2,330
That's a lot of crap, to put photos up go on photo bucket and copy and past the img code into ur thread the photo then shows up
CRNeo
403
7
Liverpool
Just fitted some LED DRL bulbs and they seem to have worked with no errors so far and look epic. [B)]
Also discovered a bit that's not attached properly under the engine bay, possibly from when the dealers did my clutch.
It's the bit at the very front under the air filter part of the air intake? The lid doesn't seem to fit properly now? :confused:
Bigjohn84
May 5, 2015
2,330
Is that a 19m catch can also
sockpuppet
837
Do you mean where the cable goes into the tube that feeds into the car? I removed the cable from the caliper and the fixings to the car body and from the handbrake, then I twisted the cable with pliers right by the tubing and pulled, the cable jams into the tube really tight so it takes a bit of effort to get it free.
leegreenaway
505
Merthyr Tydfil, South Wales
I thought you need specially lined hose for your catch can, that's what I'm running anyway with reinforced, it still deforms though because my tank is crap
Similar to this but red
http://www.ebay.co.uk/itm/19mm-Oil-...571103?hash=item35c756091f:g:UC0AAOSwstxVQMju
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Yes , tank was made by these folks, at the time was listed as specific for the Leon, but no longer listed on their website.
http://alloyracingfabrications.com/
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Technically yes but as this is only oil mist/vapour and condensation this type of hose will be okay short term.
As I said I'm not happy with the layout or hoses so am looking for a better way to do it , so new hoses and either relocate the tank or replace it.
leegreenaway
505
Yeah it's not there, they've switched to a more universal can now and can mock it up.
I've put an email to them though seeing if they can still do the version you've got, it's perfect for that location see and can even be mounted on the battery cover and routed nice!
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
That's where I am thinking , I looked at relocating the battery yonks ago , bought the bits but never did it, I may just have a look at the weekend.
Although there is a much better option using the Forge breather adapters and dash-10 fittings to one of their tanks with dash 10 fittings, that would be a really neat solution but a tad expensive maybe.
leegreenaway
505
Be worth it if you're looking at track applications for definite!! You'd probably pick up a custom fabricated one with the relevant connectors cheaper then buying from forge though
Bigjohn84
May 5, 2015
2,330
How do you get the new cable, through the pipe then?
Brewster
My wingmirror covers were covered in chips and the laquer was peeling so I've sanded them down and started to repaint them
