My wingmirror covers were covered in chips and the laquer was peeling so I've sanded them down and started to repaint them
Gave the exhaust hanger brackets a clean and coat of paint before fitting new rubbers.
Then Clean, Polish and Wax.
New discs and pads on rear ( did fronts separately last year). Easy to do apart from the sodding Philips head disc retaining screw. I now have 3 wheels with it snapped off (grrr why can't garages lubicate the threads of these when fitting new discs?) All done and working mighty fine .
IE rods fitted and ARP bolts, new big end shell's , rings , valve stem seals head skimmed and pressure tested. New gasket and head bolts new oil pump kit , timing belt kit and water pump coolant flush , new coolant oil flush and new oil and filter. Remap and water meth in next week or 2 . Running turbo technics stage 4 k04 hybrid bosh 550s badger5 tip ramair heatshield and air filter oh and a wellycooler. Better hit over 300bhp @ fly. Last outing was 252 @ fly on stage 1 map on a realastic RR .
Painted my callipers with an E-Tech kit. Went for graphite grey...
(bumper on the right is getting resprayed next week)
After fitting a new welly intercooler, Badger5 v3 intake kit with filter and heat shield, replacing the water pump and cam belt I've now purchased a set of KW Clubsport coilovers to replace the prosport coilovers I fitted a few months back.
Can't wait for a bit more knuckle bashing!!
Replaced this lot for some nice new hoses, couldn't believe the amount of tape and various bits of hose held together on the manifold breather!
Next up is new wishbones and dogbone bush.
Fitted new brake discs and pads at the front a few days ago, and just spent the weekend disassembling and reconditioning all the door lock modules on my LCR. Turns out most of them had a "new" problem other than the solder joints going - the motors were lacking torque and occasionally stopping in a position where they couldn't start again. Disassembled the motors themselves, cleaned the carbon off the commutator and adjusted the brushes and all working dandy now!
Car washed just in time for it to start raining :) carried out the n249 delete, got rid of rear wiper and sorted a few niggly faults around the car. Might fit some spacers to the back wheels tomorrow to fill the arches out a bit. Out of interest is there any easy way of finding out who has VCDS around Huddersfield other than asking in a post. I used to be on a site that had people dotted on a map that had software and were willing to help?
Gave it its yearly clean took it down for its mot passed no probs hopefully another years hassle free driving lol
What car you driving mate, positive I've drove past you a few time at Granton square. Maybe wrong guy lol
Not today but at the weekend I started painting the cage after being let down by 2 sprayers
Currently all in primer but needs a few small areas touching up, colour is mixed ready to go on just need the time to mask it up now
