If you have a mk1?
You will need a subframe to mount to.
Sparco may do one. OMP do a version for mk4 golf that’s thecorrect version .
Pic shows code numbers for correct OMP.
probably need to drill couple of holes in it too so bolting points line up with your mounts.
If wanting it to slide then slider kit from sparco or corbeau fitted between mount and subframe.
This again adds height.
Be aware you may need to grind height of subframe away to get desired height.
Hope that helps.
Badger5 Custom Map + TIP,
3” Sustem, FMIC, Bosh 550’s,
BC Coilovers, ARB’s +loads more.
I haven’t done mine yet
Doing it this week if I get time.
Grabbing additional bolts tomorrow as I have runners to fit too.
Far as I know once old stuff is out it bolts to the car as opposed to the runners. Should be pretty evident when you offer subframe in.
Looking like I need to drill new holes in subframe too.
Looking at their paperwork it seems it all bolts into existing holes on the cars floor pan . Far as I can tell.
