Hi people,
I need of some
help/advise.
Bought some Sparco seats to replace the front seats, they came with mount similar to these:
Do i need anything else to fit them as i cant seem to figure out
how to fit them with just the above.
James
If you have a mk1?
You will need a subframe to mount to.
Sparco may do one. OMP do a version for mk4 golf that’s thecorrect version .
Pic shows code numbers for correct OMP.
probably need to drill couple of holes in it too so bolting points line up with your mounts.
If wanting it to slide then slider kit from sparco or corbeau fitted between mount and subframe.
This again adds height.
Be aware you may need to grind height of subframe away to get desired height.
Hope that helps.
Badger5 Custom Map + TIP,
3” Sustem, FMIC, Bosh 550’s,
BC Coilovers, ARB’s +loads more.
