Well mine is 2014 so check out the link I put above and you can see all the adaptions and long coding descriptions.
Afternoon i am trying to code my leon fr 2016 with LED headlamps to have front cornering lights using VCDS but its coming back saying out of range. Can anyone assist me please ?
Also ive tried doing one touch mirror folding and also this has failed im quite stumped.
This is using a lead and software that my master tech uses here at a vw main dealer.
This is how I did my mirrors,
Select 09 (Central Elect)
Select 16 (Authorization)
Enter Unlock Code 31347
Select 10 (Adaptation)
Choose (22) Access Control 2 Radio(Funk) Spiegelanklappung Mode.
(I have a feeling when I did mine it wasn't under (22) I think I had to scroll
down to find the description under a different number).
Change options as below,
Stored value = by convenience operation via remote control key.
New value = by look?(think this is meant to say lock) command via remote control key.
Then Do it!
Yesterday I bought this one: https://www.auto-intern.de/shop/diagnose-adapter/51/hex-v2-inkl.-vcds-lizenz?number=AI10040
I' ve been working with a clone cable for years now, no problem at all. I did lots of mods to my old 2009 Q5. With the Copra now I could not make it work even with the 18.9.1 vcds. It said that the vehicle is unsupported for long coding. I excahnged some emails with Ross Tech and they kind of confirmed that the original cable will work (if not immediately, maybe in a few months) with the Copra and I will be able to retrofit the Seat Sound System and the backup camera which are my two main concerns for now.
If anyone has any idea about vcds compatibility with the Copra or even more specific info for the afformentioned retrofits, I'd be happy to know.
