decided to swap out the usb location to the centre console what a pain in the backside that is to do the existing HSD/USB harness is not long enough to move the location and my cheap aliexpress cable fell apart on first use, what a piece of junk. ended up having to take apart harness remove the old ami/media in cable as that is not used anyway cut the original usb cable in half and splice a new longer lead in shrink wrap the connectors and then fabric tape it up like an original cable. vw want £45 for a usb cable
if anyone goes down this route be careful which harness you buy as the quality of some of these cables are shocking.
old ami cable removed from harness
. if anyone goes down this route be careful which harness you buy as the quality of some of these cables are shocking.
