unless that's a new efficient technique produced by the germans!
Burns less fuel / more MPG!
Mine fell into the door on sunday so it was a bin bag cocooned in gaffa tape until i got to work lolView attachment 7713
Window regulator packed up whilst out so daughter's hair curlers saved the car from a heavy soaking!
Ay she came outa the woodwork from many moons ago so stuffed her in there so our lass didn't find out. Plenty of water leaking in and im sure some biscuit crumbs made their way in there. She'll be reet...what, your daughter fell into the door on Sunday and you taped her in there!?!?
These transformed the handling of my car,I went for 2.5 degrees of neg camber.New adjustable top mounts turned up today.. shame I can't fit them yet as shocks gotta go back and get modified lol. View attachment 7719
To be honest it does just look like the paint has cracked and gotten worse over time but If you get the tracking done and all is OK then I wouldn’t worry (they are pretty solid bars)
If you do want one .let me know I have just chucked one in the skip as I am converting to lcr set up
It looks to me as if it’s just the powder coating that cracking and the bar underneath is just going rusty it will be fine as they are think bars so noting to be to Concerned about. I would look to see how your Flexi pipe is and how bad it’s rubbed as it looks as if it’s rubbing on the anti roll bar
Thanks for this - I'll have a look tomorrow when they've got the wheels off for the alignment. I think there might be a gap, but you're right - I need to find out where that mark has come from.
They should not need the wheels off for the alignment
I get that with G101 (inerior plastics soap) so i just water it downWas given loads of Chemical Guys cleaning products and 90% of them have been brilliant (and smell like you want to eat them) but the Interior detailer which at first looked good leaves white streaks if rain manages to get in through the window onto it.
Gave the interior a clean up with Halfords own Dash & Trim cleaner, heard it was good and for £4 worth a go. It's loads better and took off all the old residue from the Chemical Guys stuff.
