Has anyone every replaced the wire loom from ecu back into car is there a guide on how to do so and also require another loom as mine is toast.thank
Never done a whole car loom swap like this but all I can say is best of luck because it’s going to be a big job. Mines stripped out for track and I’ve deleted as much loom as possible and there’s still a lot!!
Which loom exactly, the main one that runs back through the nearside firewall behind the glovebox?
I had the gromet for the bonnet catch missing so i belive water has gone straight down on to what is plate a
section holding 5 or 6 plugs
You can't just take the loom out. You need to unholy and remove the bulk head where the wiring passes threw on the left hand side the loom is to big and the plugs won't pass threw the hole
You can remove the full car harness and the plugs do pass through that hole if you're very meticulous about the order you pull them back but **** me it's a huge task, I'm speaking from experience as well.
The main harness that goes along the nearside chassis leg essentially goes right back along behind the dashboard and around the entirety of the car right back to the number plate lights.
Only real substantial loom that is separate is the engine loom which goes from each sensor back up to the ECU then back along the scuttle to the coloured plug board you're talking about.
I am only asking as i havnt tryed this before and just from looking i assumed that the plug from ecu into car was just the case of unplugging and pulling through to then remove the rest of plugs from inside the back of dash.
No one i know around will tackle the car as they all belive its the ecu at fault but i belive its where the water has gone in plugs and into wires below the dash.
So its a very big job then haha
I will be stripping the car down soon to change it up so be best time to do it i guess thank you for the advice and help.
Mine is already stripped.. waiting for suspension to come back from GAZ then I can start welding the cage in
Yep stripped bare. Weld. Fit seat rails and fuel cell window net fixings. Then paint.
It's gonna cost. Lol like my front subframe.
New front subframe
Spherical rear lower arm bushes
Camber adjustable front bushes
Bush inserts to reduce from 45mm to 30mm
Silver project adjustable top mounts
New cast lower arms
New ball joints
Recon cupra r rack
Powerflex black rack bush
New track rods
New rod ends
New gators
New cupra r hubs
New wheel bearings
Gaz mono tube suspension
New top mount bearings
All new nuts and bolts
25mm neuspeed antiroll bar
Adjustable drop links
That's will I can think off.
That's just the front end lol
Reactions: Nizza
New front subframe
New cast lower arms
New ball joints
Recon cupra r rack
New track rods
New rod ends
New gators
New cupra r hubs
New wheel bearings
Can’t wait to see you on track to see what sort of differences our cars are gonna make seen as we’re doing same things with different parts etc.
I recon it's gonna be a year or so till it's ready to race but until then. I am up for track day in this beast until it's soldView attachment 7963
I have 5 weeks before the ring....and it’s happening because I’ve paid for the ferry ha ha. Yeah sound like I say hoping for Cadwell or donnington evening session in 3 weeks
