Hi, everyone I have ordered a Silencer delete pipe off eBay and will be installing it tomorrow.
Has anyone done this before?
What is the best tool to cut an exhaust and is there anything i need to be careful off.
BTW, pipe from Zhasutworks
No pictures mate,Hi,
Im also looking to fit a mid silencer delete pipe to my Ibiza FR.
How easy/hard was the install?
Do you have any pictures?
Cheers.
Cheers Adam
Ah that's good to know as it does look fairly straightforward.
I've actually found a delete pipe that's from another seller on ebay which is currently on special offer so i'm going to go with that one & hopefully it will fit as it looks identical to Zaustworks but our car is not listed
Pops & bangs on start up!? Is the rest of your exhaust system still factory OEM?
Unfortunately im not on insta
Have you put any exhaust clips on youtube?
link to the add nearly impossible to find ahaIt's 'clickcarparts'
He currently has his delete pipe on offer for £29.24 inc. p&p
This should work..
But I am now looking for a back box removal let me know if you find any sellers. Mid res just the icing on the cake!
Looks like that one COULD work. Im going to have a look under my car and see if it would fit. However yeah don't know if there are any differences between the 6j and 6LI initially looked for a back box delete myself and did not come up with any exact items listed for the 6J.
However, I did find item number 273996131692 on eBay which again as per the 'clickcarparts' resonator delete pipe is listed for an Ibiza 6L. If you however study the pictures on the listing and that of a 6J rear section they look practically identical. At £95 Inc p&p maybe it's worth a try?
Just an update for anyone looking into this. The above Ebay item number in relation to the Resonator Delete from 'clickcarparts' will only fit an Ibiza 6L as listed and not a 6J as I have since found out the the bend of the two pipes is slightly different so it would not be a direct fit as previously thought.Ahh sorry
Item number is 141679595117
