Seat Ibiza FR 1.2TSi Centre resonator mid silencer delete pipe.
ITzadamZz
66
Hi, everyone I have ordered a Silencer delete pipe off eBay and will be installing it tomorrow.
Has anyone done this before?
What is the best tool to cut an exhaust and is there anything i need to be careful off.
BTW, pipe from Zhasutworks
Alfski
44
18
Herts/Essex Border
Hi,
Im also looking to fit a mid silencer delete pipe to my Ibiza FR.
How easy/hard was the install?
Do you have any pictures?
Cheers.
ITzadamZz
66
Hi,
Cheers.
No pictures mate,
Easy install simple as cutting the old pipe removing and replacing it with the new one.
Would 100% recommend. I’m getting pops and bangs on start
Took around 2 and a half hours to install but can definitely do it by yourself with some axel stands.
Request to follow Blue_Ibiza_Fr_
On Instagram for some videos
Thanks Amy more questions feel free to ask
Alfski
44
18
Herts/Essex Border
Cheers Adam :happy:
Ah that's good to know as it does look fairly straightforward.
I've actually found a delete pipe that's from another seller on ebay which is currently on special offer so i'm going to go with that one & hopefully it will fit as it looks identical to Zaustworks but our car is not listed :think:
Pops & bangs on start up!? Is the rest of your exhaust system still factory OEM?
Unfortunately im not on insta :shrug:
Have you put any exhaust clips on youtube?
ITzadamZz
66
What eBay seller is This I will have a look
Cheers Adam :happy:
Reactions: Hilly93
ITzadamZz
66
But I am now looking for a back box removal let me know if you find any sellers. Mid res just the icing on the cake!
Alfski
44
18
Herts/Essex Border
This should work..
That's what I thought but when I messaged to check fitment he says my car is not listed and he tried to find one but couldn't.
As far as I can tell when compared to the Zaustworx delete pipe that you've fitted they look practically identical and follow the same pattern so I can't understand why it wouldn't fit all be it with maybe some minor adjustments.
The 'clickcarparts' listing has it down as an Ibiza 6L fitment but as it appears to follow the same route/shape as the 6J I see no reason why it shouldn't fit.
I reckon I'll give it a try and will see what happens :think:
Alfski
44
18
Herts/Essex Border
I initially looked for a back box delete myself and did not come up with any exact items listed for the 6J.
However, I did find item number 273996131692 on eBay which again as per the 'clickcarparts' resonator delete pipe is listed for an Ibiza 6L. If you however study the pictures on the listing and that of a 6J rear section they look practically identical. At £95 Inc p&p maybe it's worth a try?
ITzadamZz
66
Looks like that one COULD work. Im going to have a look under my car and see if it would fit. However yeah don't know if there are any differences between the 6j and 6L
Alfski
44
18
Herts/Essex Border
Yeah its annoying because lots of stuff seems to be listed for the 6L but not the 6J.
When you look at pictures/diagrams of 6L & 6J exhausts respectively they both look virtually identical so hopefully only minor adjustments if any will be required to fit.
Alfski
44
18
Herts/Essex Border
Ahh sorry :hide:
Item number is 141679595117
Just an update for anyone looking into this. The above Ebay item number in relation to the Resonator Delete from 'clickcarparts' will only fit an Ibiza 6L as listed and not a 6J as I have since found out the the bend of the two pipes is slightly different so it would not be a direct fit as previously thought.
Sent from my SM-A505FN using Tapatalk
