Carbon fiber informant screen is vi the dev mode on the actually MIB system when holding the menu button for 10 seconds, I think it’s under he skin section.Has anyone managed to do the 'mode button always red' on Carista BETA? I couldn't find the option yesterday.
Also wasn't able to centre screen carbon fibre, not sure if this is available?
2018 Facelift car. Thanks
I couldn't get into this menu on my facelift, do I need to enable it in Carista first?Carbon fiber informant screen is vi the dev mode on the actually MIB system when holding the menu button for 10 seconds, I think it’s under he skin section.
the mode menu button colour change is on my Carista beta app
Driving mode button in red isn't available on facelift cars. The programming for lighting in facelift cars is different from the pre facelift carsI couldn't get into this menu on my facelift, do I need to enable it in Carista first?
I will look for the mode again - it was on the Driving section on my Mk7 Golf which I did manage to change yesterday but didn't see it on the leon!
Oh how annoying! I will have to see if I can take the switch apart and put something red in it as this really annoys me!Driving mode button in red isn't available on facelift cars. The programming for lighting in facelift cars is different from the pre facelift cars
yes you unlock the dev menu with Carista then it lets you hold the menu buttonI couldn't get into this menu on my facelift, do I need to enable it in Carista first?
Then how do I change the background?yes you unlock the dev menu with Carista then it lets you hold the menu button
Read above post, hold menu button the 10 second and navigate to skins and I think it’s from an option of 3Then how do I change the background?
Hmm, nothing seemed to happen when I pressed them but will try again.Read above post, hold menu button the 10 second and navigate to skins and I think it’s from an option of 3
i got it to work, by adding the option to my MIB menu then you have to select on the menu, think its classed as an acoustic noise on the lock/unlocking menuSo I got my carista today and tried setting the beep when locking and unlocking but it’s not working?
I pressed the menu for configuration button I couldn’t find this in settings, do I need to find this and enable it?
My car definitely has an alarm as it was set off earlier today when kids were moving around in car
Could you tell me exactly where in settings I would find it? Is it in the same place where you set if you want the doors to lock after moving off etc?i got it to work, by adding the option to my MIB menu then you have to select on the menu, think its classed as an acoustic noise on the lock/unlocking menu
Yes it should be be on that screen on the mib screen. I thought mine didn’t work until selecting the optionCould you tell me exactly where in settings I would find it? Is it in the same place where you set if you want the doors to lock after moving off etc?
It’s a Seat Leon 2014, so was pretty surprised when it didn’t work as the main reason I got carista was for this after seeing youtube videos and people recommending it on here
no worries 100% relatable, was thinking the exact same when I first purchase the product, enjoy!!!.Thank you!! Just found it and it works! Saved me from thinking i had just wasted £15.99 haha
You need the dev menu enabled via the app before anything. Then go back to your MIB screen hold the menu button for 10 seconds that will open the dev menu and on that screen advanced to skins and it’s on there from a choice of 3 I believe.Bit confused about how to enable the carbon background in mfd.. could anyone explain? I've enabled the developer settings but nothing happens when I hold the menu button on my mfd. It only brings up the settings to update the software etc
