Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
So I haven't been able to hear as well as I would have liked this week, with a cold and all. Clearing up now though.
I generally listen to rock music, and would rarely have dance tunes on in the car, so take this with a pinch of salt. I also play bass, hence wanting a little more than the stock speakers, though they're fairly decent.
Pros
Adds subtle depth to the system
Makes it easier to hear the bass when driving at motorway speeds
Does what it's supposed to do
£100 - fairly cheap
Easy enough to install (once you get a little help)
Cons
One puts the sound off balance, I hear it all from the passengers seat (earth lead not very long, wouldn't reach to the drivers side, I'm not sure if there are any earth points on the drivers side)
Clarity isn't the best, it adds depth but can be a little muddled when complicated bass lines come in.
Improvements
2 of them, I think this would seriously improve the sound and be greater than the sum of the parts.
Maybe upgrade the speaker to say the focal ibis, which would be a little clearer I think.
All in all, I'm very pleased with it and would do it again.
I was looking at maybe upgrading the speakers in the doors. I did also think to fit 2 of them should cash permit at some point. As you said it does add depth to the system.
Exactly what I thought so that's what I did. And it made a big difference in spreading the bass around the inside of the car.
Also mine sounds better 180° out of phase. Yours may differ......
When I was looking about, I think focal had a specific VW golf set you could buy, which would be a straight swap.
Though the Leon speakers are decent imo
Just put of curiosity, I assume I can just extend the earth cable? It's not long enough to reach below drivers seat. Would I just get a 14 guage wire and connect the two with and cover with electric tape/ heat shrink?
Sorry to bring up an old thread but does anyone know if it would be ok to put a quad lock extension harness between the media unit and the existing harness to splice the sub in to the speaker cables?
Thinking it would be easier to do the splices on this first and would also save damaging the car wiring
Here’s one like I’m thinking of, although it’s now out of stock -https://www.amazon.co.uk/Most-Quadlock-Extension-Connector-Adapter/dp/B00I0YXNTI
TIA
Thanks I’ll get one ordered up and give it a go this weekend.yes, I just did this this weekend, was a bit of a struggle getting wires from glovebox through to centre console but managed it. would of been easier to take the whole glovebox out but I like to do things the hard way!
Now there is an idea....Sorry to bring up an old thread but does anyone know if it would be ok to put a quad lock extension harness between the media unit and the existing harness to splice the sub in to the speaker cables?
TIA
Edit:- Have just been looking for a quad lock extension and there seems to be 40 pin and 52 pin ones, which one did you use?
That is pretty cool, but no use to me and my family lolthis is the one I'm using..
https://www.ebay.co.uk/itm/352194322697
in-case anyone's interested this is my project that I'm half way through, just got the sub wired up this weekend actually but only to the OEM head-unit and standard speakers. sorry for the bad picture! if there's any interest I'll start a proper thread on it.
View attachment 12824 View attachment 12823
