Cheers mate, at least one of us is enjoying themselvesLoving this thread Thai, keep it up.
This shows the functionality, albeit in their old TDI state.
Absolutely not, I can't stand the standard clocks plus they're not compatible with the cluster board due to the lay out of the warning lights etc.Sorry to drag up an old post, but just read through from the start, but did you try and fit the LCR foils over the black foils? Would love to have this in mine but only if I could keep the same dial face.
That’s a fair one, I’ve asked a foils manufacture if they can do the golf foils in the LCR style (personal OEM+ taste).
Looking on eBay I see there’s different full FIS clocks anything I need to make sure I get as I see the Audi A3 versions have the round fuel and temp so may fit better?
Lastly how hard is it to change the mileage to match my car as most are 140k plus? I will have to find a specialist to do the immobiliser but don’t want to have to switch clocks back every time it gets an MOT (plus they will be out).
Apologies, I've only just noticed that I hadn't replied to your questions.
You can't use the A3 cluster foils or boards, they differ considerably due to the warning light lay out and boards have 3 plug sockets instead of the 2 found on the mk1 Leon and mk4 Golf/ Bora.
Only the S3 8L cluster bezel can be used with the mk4 board for a direct fit on the mk1 Leon dashboard which has the round fuel & temp gauges unless you customise the mk4 Golf or Passat bezel to suit which certainly isn't a 5 minute job.
Mileage correction isn't difficult but does require specific software and OBD cables eg. Vagtacho, Vag Commander
As for the immobiliser, you'll just need the cluster recoding to match the ECU which requires VCDS.
Ray is God in this department and ive been using his services for many years.Thanks mate, need to find a specialist to code it and swap to the full colour MFA as I’ve sorted the foil (colour) issue as I can get custom white ones made.
https://www.facebook.com/aRdTechnik/
I will when I get the chanceCheers I will drop him a line.
Also you can’t tease about the new functions and not share! Get it done and let’s see a video!
