AndrewJB
Guide to updating RNS310 Firmware
Jul 18, 2020
11
Not sure if anyone can provide any further guidance but I'm getting an error cd message on the rns310 even tho I've used 7zip to extract and used imgburn at its lowest speed to burn it but still no success. Not sure where I am going wrong.
Sent from my SM-G955F using Tapatalk
Jul 18, 2020
11
I can see which software was recommended later today. :)
did you manage to find out which is the best recommended software to use to burn this, am not sure if using verbatim cd-r discs is the issue or not but once I burn it the file is on the disc but it just is not loading up when I put it into the unit.
Jul 18, 2020
11
I used cdrwin 5.05!
It should work. You must burn the discs at the lowest speed possible.
I've tried it and alcohol 120 still having no luck. I've loaded it on to powriso which is saying that the image files are non bootable ?. Not sure if I am missing something here. Burned through 10 CDs already lol
Dec 14, 2020
Hi guys, i've just got a EOS with RNS310 firmware 0235. I'm looking for firmware to upgrade from 0235 to 351. Some one can help me please ?
