So, looking at all these bars, am I understanding correctly that Seat one and cheapest Thule one doesn't support accessories fixed using t-slots?
I don't have experience with roof accessories.
Me too. Bit confused about what I need to buy. I just wants to use it for transporting a couple of kids bikes
Thule!
So, are these Thule roof bars universal, for different car models or specific one? I have to do some more reading on it. If they are universal, then I will look for them on Ebay.
Think I’ll be opting for these now I’ve got my head around what’s needed.
I think you can get the Evo 118 wing bars for about £85 if you search online and Halfords do the Evo raised rails for £88
Reactions: CupraPoopra
Yeh seems to be best buying from separate sites. There’s also a fair few knocking about second hand online.
Reactions: IanH72
Thule WingBar Edge 9584​
I like them better than Cupra because they stay in a lower position.
Can confirm the Thule Evo Raised Rails pack 7104 fit perfectly. Got mine from ebay this week. They also fit with the older Thule Aero bars which I've had since 2007 on a variety of different cars. These bars also have the removable rubber strip in the top which you take out to then slide in the bike carrier(s). These are standard fitment T section and you can get them cheaply and fit 1 to 4 on the roof. I've had these cheap Halfords ones for years and they're OK https://www.halfords.com/cycling/bi...cks/halfords-roof-mount-bike-rack-635780.html
Hope that helps.
Hi all, sorry to hijack an old thread. if I'm looking for bars to fit the footpack, what width am I looking at? I'm hunting on ebay but want to make sure I have the right width
Do you have the Thule "Raised Rail" footpack? And by width, do you mean across the car? The bars are all the same length from Thule, all that varies is the profile. Look here https://www.thule.com/en-gb/roof-rack/car-roof-racks and you'll see all the options. They all use the Raised Rail footpack.
So I'm in the process of getting hold of a Thule 757 footpack, yet need the bars, I thought the 118 etc was the width across?
The link I sent last reply shows all the Thule options. Pich the one that suits you - but I'd advise against the square bars as they're very noisy if left on.
Beware, Thule roof bars do vary. It's not so much the length per se, but the length of the cut out underneath. This will limit how close your roof clamps can be, with the Formentor the rails taper in towards the rear. I tried to use different Thule bars and wasn't able to get the rear clamps close enough, although the front one was fine! You definitely need the 118s, here's the correct Thule link: https://www.thule.com/en-gb/buyers-guide?c=roof+racks&q=LkfGCwjDH
Reactions: jackliebling
Reactions: Agnes.Surrey
Haha right, I've ignored everyone and gone for a punt on these :geek::geek::geek:
I thought as a trial lets see, this will be used very infrequently so not keen spending 100-200 quid on some!
Will feed back when they arrive
Tbh I got mine secondhand from eBay ?
Wish I’d found this forum/thread a few weeks ago. I’ve been in the process of buying a roof rack and box ( due to the boot not having enough space when going on holiday).
Can confirm the Thule 118cm bars and 7104 foot pack fit perfectly.
If anyone is also after a roof box the Thule XT motion in medium is also a good fit. No front over hang and allows the boot to fully open. Also has a cut out for the roof antenna. Height with bars and box is approximately 198cm (I’ve given myself an additional 5cm on top of that for piece of mind when entering a car park).
It’s been mentioned in the thread that the roof limit is 75KG. I was under the impression that it’s 50kg. Is anyone able to confirm the max weight limit please.
PS really enjoying the Formentor. I seem to find new features on a daily basis ?
Reactions: Nickfurnell
The max roof pressure is indeed 50kg (metnioned in the manual), this is including the Thule roofbars and roofbox.
BTW: do you have a panoramic roof, if so , can you still open it even when the roofbox is on the roof?
