Aug 18, 2021
Hello all, I own a 2020 Leon cupra and I am having a problem figuring something out.
my car is left side driver. I managed to get the right mirror to lower if I put the mirror knob in R when I reverse.
I cant get the left side mirror to do the same, can anyone help me? When I select L and adjust the mirror, the right mirror also gets adjusted and then when I select R and adjust the right mirror, the left one goes back to default. Thanks :)
I believe that on the MK3 Leon, only the passenger door mirror can be set to lower when reverse is selected.
You can only get the mirror on the passenger side to dip. The drivers mirror doesn’t dip.
There is a item in the menus to choose whether the mirrors adjust together or separately.
Yep, but doesn’t affect the dipping in reverse. That is only the passenger side when the adjuster knob is set to select that mirror
Thank you all :)
