Best place to buy new brake disk (Sub 8)
MH0
45
Hi All,
Just need some help. My cars brake disks are worn and require changing. I currently have the big brake kit with the brembo pads and the bigger brakes which come standard on the sub 8 pack.
Does anyone know where I can find the exact disks which come with the car? I'm looking to have the front and back changed. Also, I'm unsure on what to get for the back. I presume the back disks and pads are standard to all Leons?
Any help would be appreciated.
Thanks in advance
black_sheep
1,256
586
Reactions: MH0 and TheSwede
black_sheep
1,256
586
MH0
45
Part numbers are here:
Sit down before you see the price:
The next month is going to be a big hit for me... Looking to replace all my disks and pads along with a full service. Thanks for the help, unless I can find it cheaper than £500 for front disks. Looks like I'll have to just stick with buying from seat.
I'm guessing for the rear pads I could just order the ones on euro car parts?
Stefan147
193
140
Athens Greece
You can always opt for the Zimmermann alternative which is 15-20% cheaper. I've been using them for more than 10K km now plus one trackday (during which I stupidly forgot to cool down properly and I got a 30cm flame out the brakes) and they are great. Zero wear although I'm using a pretty aggressive Hawk pad.
https://www.autodoc.co.uk/zimmermann/8761332
Reactions: MH0
MH0
45
I've got the brembo kit at the front. Im guessing these would fit perfectly fine? Only thing left is for me to find some good front pads now
Stefan147
193
140
Athens Greece
Yeap. Perfect fit. 370x32mm.
Pads are very easy with these calipers. There are tons of options depending on your needs. ATE ceramics would be a good all around pad. For spirited driving and the occasional trackday I would suggest something like Hawk or Pagid.
ATE 200 is also a good and vmf brake fluid which you will also need.
MH0
45
Im looking to buy these pads - https://www.eurocarparts.com/p/pagid-brake-pad-101441858
Do you have any idea how they compare to the Ferodo DS2500 as those are the pads I currently have and they have been amazing.
Also I appreciate all the help. You and the others have been amazing! Thanks
Stefan147
193
140
Athens Greece
They should be fine I guess. DS2500 are sports pads though so they don't really compare with those Pagid ones. They are double the price as well.
MH0
45
True. Just came across something on google. It said that brake disks should last around a minimum of 80,000 miles. My car has 25k miles on the clock and i’ve never been on a track. I don't often do spiritual driving its occasional.
when I went to get my disks changed, kwik fit mentioned that it needs changing. How has my disks worn out so quickly. Could that pads have an affect on that?
Stefan147
193
140
Athens Greece
80.000 miles? Not on our cars. 25K is not much for a disk to get worn but it all has to do with the driving style and conditions. DS2500 are aggressive and can definitely eat some more disk but not so fast. Check your disk's width before replacing them. They should be more than 30.6mm.
Alzak
666
Kwik Fit mentioned mine brakes need doing two years ago 16k miles later (a week) ago passed MOT for a second time (with no advisory) since Kwik Fit mentioned my brakes need doing...
Sent from my EVR-L29 using Tapatalk
Deleted member 126886
Drop me a PM, we stock EBC and Ferodo brakes and offer members discount 👍🏼😊
Reactions: Woody_72
Woody_72
502
251
Northwest England
Never, ever take what a chain like KwikFit tell you about things needing replacing seriously. Far better to buy a cheap set of micrometers for £30 and measure them yourself or take them to a good independent specialist or a local mom and pop type place. Chains like KwikFit make their money flogging easy to fit parts to customers with ZERO car knowledge.
Reactions: mty12345 and jdubya
SuperV8
1,344
594
I know its a few months old but those 'cheap' Pagid pads are not equivalent to DS2500 or Pagid's other racing pads.
As mentioned I would get a second opinion on your brake wear, especially given how expensive your discs are! 30.4mm is the minimum disc thickness for your front discs and 20mm for the rear. You can measure this with a cheap vernier caliper.
RUM4MO
7,823
1,000
South Scotland
A tip when using digital callipers to measure things like brake discs that have a lip at the edge - grab a couple of metal washers, new flat ones, and zero the digital callipers with them in the jaws, then hold them against the disc in beyond the lip and measure the combination of washers and disc - doing that will stop you accidentally catching the "jaws" of the digital calliper on the lip.
Digital callipers are easier for most people to use and don't need to cost much more than £20 and have many uses around the garage and house!
Reactions: Woody_72
SuperV8
1,344
594
Yes, good point - you want to be measuring the thickness of the disc friction surface - NOT the lip at the edge of the disc. Pick washers or maybe a coin which are thicker than the depth of the lip.
You can get digital calipers for £5! fine for measuring disc thickness, and jobs around the house.
