Have you heard a noise like it before?Sounds like one or both CV joints have crapped themselves
I havnt tried to be honest. If it is drive shaft, it should still make the noise when rhe car is lifted.
I don't have the space, but I do like doing the spanner work - but that has led me to places I'm probably not qualified to work or I'm a bit out of my depth. It just really gets to me the amount of money some people spend at garages when if they have the time, it's an easy job, and I haven't really worked out where to stop.
The car still drives though, so I can't have done too much damage over the years.
I'm just looking at tools to do the nearside front wheel bearing while it's on the car. I find the biggest problem is that I'm not as fit as I used to be, so the heavy jobs knacker me out.
Thankfully most of the jobs I need to do right now are in the engine bay, but we all know that's not without its problems, and those jobs always mean I end up with raw knuckles - even if I'm just topping up the washer fluid.
Done today? Buttoned everything up in the engine bay, started car, no issues (yay! I'm not a complete idiot!), turned off car, swore repeatedly at self for forgetting to put oil in it (I retract my previous statement), put oil in it, fitted EBC Bluestuff pads on the front, got most of the fittings done for the Maxton front splitter
I've got a lot of respect for anyone who does a cambelt. It's not just getting the timing right, it's getting access, from the hoses full of liquid to taking off the engine mount. It's a proper job.
I would have put that down as one of the worst parts of the job. Drain the rad and coolant still pisses out when you remove the water pump and it gets everywhere!Yup, never understood when people don't get that done at the same time
sounds like a Rachet winding wtf not heard that before, have you removed the cv boot clip and had a look at the bearings if dry? or check any rips in boot? cv boot clips been changed on mine a few times and had 3 cv boots also
Its a new one on me.
Is this a new electric leon.. very quiet running.. apart from the squeeze
