Hi,
I’m having an issue with the driver side aircon zone vs the passenger side.
While the passenger side show ”100% temperature achieved” the driver side zone temp says ”45%…” an therefore heat one side and cool the other at the same time although the real temp is the same on both sides. It would make sense if there was a big temp difference but that’s not the case. I normally set the temp to 20-21 degrees and the zones are synced. Just guessing it’s a sensor issue that the dealer need to check.
Anyone else experiencing this?
I’m on sw1804, maybe solved by sw1896?
