Driving pattern. Sometimes I visit a Trackday but mainly I use it on ordinary roads. I have been pleased with the OE-pads so far but the SEAT dealer are rather expensive so this time I want to see if I can replace them with something else.
I have the OE-pads today. In front the brand is Pagid with Audi logo.
OE-equivalent replacement pads from Brembo.
P 85 159 Front with squeal shims (disc 370 mm Brembo caliper).
P 85 124 Rear.
P 85 124X Rear, Extra perhaps more durable but I prefer the same type on both front and rear.
Is this a good choice? I don’t mind changing pads now and then so that’s not an issue.
https://www.bremboparts.com/europe/...1?producttypes=Pad&isProductListFiltered=true
Another possible way to go is to order Brembo HP2000 pads.
I suppose this is the relevant numbers to use if I go with HP2000:
07.B314.83 Front.
07.B315.41 Rear.
Of cause these are more expensive but perhaps I will have some other gains. I have no experience of HP2000.
Pro and cons? Do the HP2000 cause much extended wear on the discs? Do they squeal a lot?
Grateful for some input in the matter. . I have searched for an answer on the forum but not found so much.
FYI I already have the front pads Brembo P 85 159 at home. Payed about 110 EUR for them at Autodoc in Germany.
/Peter
A winter pic, usually in garage in winter .
P 85 124 Rear.
07.B314.83 Front.
07.B315.41 Rear.
/Peter
