New brake pads for my Leon III Cupra R 2018 with 370mm Brembo front discs.
TheSwede
371
211
Sweden
Driving pattern. Sometimes I visit a Trackday but mainly I use it on ordinary roads. I have been pleased with the OE-pads so far but the SEAT dealer are rather expensive so this time I want to see if I can replace them with something else.
I have the OE-pads today. In front the brand is Pagid with Audi logo.
OE-equivalent replacement pads from Brembo.
P 85 159 Front with squeal shims (disc 370 mm Brembo caliper).
P 85 124 Rear.
P 85 124X Rear, Extra perhaps more durable but I prefer the same type on both front and rear.
Is this a good choice? I don’t mind changing pads now and then so that’s not an issue.
https://www.bremboparts.com/europe/...1?producttypes=Pad&isProductListFiltered=true
Another possible way to go is to order Brembo HP2000 pads.
I suppose this is the relevant numbers to use if I go with HP2000:
07.B314.83 Front.
07.B315.41 Rear.
Of cause these are more expensive but perhaps I will have some other gains. I have no experience of HP2000.
Pro and cons? Do the HP2000 cause much extended wear on the discs? Do they squeal a lot?
Grateful for some input in the matter. . I have searched for an answer on the forum but not found so much.
FYI I already have the front pads Brembo P 85 159 at home. Payed about 110 EUR for them at Autodoc in Germany.
/Peter
A winter pic, usually in garage in winter :).
380bhpdaily
1,261
574
Hi I’d agree with above ebc pads are the ones especially if your going to drive on track. I’d recommend the yellow stuff as you’ll probably use it more on the road then full time track use. I’ve got these on my Ibiza and they are very good. I’ve done 10k and 3 track days and they are still like new.
Reactions: Syphon and TheSwede
Stefan147
193
140
Athens Greece
I would definitely go for some Hawk pads although they seem to be quite hard to reach.
After 2 trackdays and 20.000km of daily drive I am really impressed with them. They also seem to be very gentle with the rotors.
Oct 28, 2019
7
P 85 124 Rear.
07.B314.83 Front.
07.B315.41 Rear.
/Peter
What brakes did you go with in the end and are you happy with them?
SuperV8
1,872
941
Please don't think these Brembo aftermarket pads are the same/ or equivalent to the original & genuine pads.
Equivalent to OE is just marketing BS that all aftermarket suppliers use.
Brembo made the brake system but they did not make the pads. The original/genuine pads were made by Pagid.
I'm afraid you can't even go and buy the Pagid aftermarket pads hoping for reduced price OE pads in the box.
They might both with be 'ok' aftermarket pads - just not original/genuine.
TheSwede
371
211
Sweden
Yes you are right, the front OE pads were Pagid with Brembo logo +Audi logo, Rear OE were Ate,
@Andyoxon:
I used the Brembo ones:
P85 159 Front with squeal shims. See pic for the half moon cut out on the anti noice shims
P85 124X Rear, (XTRA)
I have just driven the car for 50 miles (75 km) on ordinary roads, Very good braking force so far. On track I can’t tell yet.
Reactions: SuperV8
TheSwede
371
211
Sweden
Some following up after track day use of Brembo brake pads, front P 85 159, rear P 85 124X. My Cupra have Audi RS3 cooling ducts on front brakes (could have some small impact…).
It was a very hot day in the middle of the summer. Parked the car under the one and only tree available. Up to +30 C in shadow. This track runs counter-clockwise, very rare in Sweden. All other tracks I have visited goes clockwise.
Everything worked as expected.
Rear – nothing to say about pads P 85 124X. The OE discs were clean. Main pressure/wear is of cause on the front pads.
Front- Good feeling in the brake pedal. The pedal felt firm also after several laps under high heat.
No lack of brake force before the tires Michelin PS 4S got little bit slippery as it does specially during hot days.
Left (sitting in the car) front disc. Looked good on both sides.
Right front disc. Wheel side had some brake pad residuals burned in to the disc. The inside looked good. No big deal. As I mentioned, a very hot day! Have experienced this before also on my former Golf 7 R under similar conditions. Normally I would just drive the car and let normal wear erase the residuals on the disc. But not this time....
Next day I decided to remove it with a sandpaper by hand. Best result was with Mirka grit 240. The “no name” grit 180 were not good at all.
The reason for sanding right disc was that I felt some minor vibrations during soft braking on my way home from track. It went away after sanding!
Summary - I am satisfied with the pads! Could buy them again.
/Peter
Reactions: SuperV8 and Syphon
SuperV8
1,872
941
/Peter
Interesting feedback.
Being a counter clockwise circuit - you would expect more heat in the right hand brake if you are braking in the bend due to more load on the outside tyre.
That heavy friction material transfer on the right hand disc is not good and a sign you have exceeded the friction material 'comfortable' working temperature. Basically the friction material has given up and unevenly depositing itself on the disc - which is the judder you felt.
Personally I would pick a different front pad friction if you are planning to do track days again.
Reactions: TheSwede
TheSwede
371
211
Sweden
@SuperV8 - Yes. I believe you are right in your conclusion.
I was a bit confused about why the inner surface of the right hand disc looked okay but the outer had some pad deposits. I will check them again after next track visit (don’t know when). Hopefully not so hot outside temp, up to 30 C (86 F), perhaps then go for something else.
We all know that the OE discs are identic left/right same item no, not directional. Cooling could work different on left/right side. In any case to hot for the pad on right hand disc.
SuperV8
1,872
941
Your RS3 brake cooling ducts will be acting mainly on the inside friction face.
You are also right on the direction veins, not being handed.
The Veins on the OEM disc below pointing to the right - mean they would be optimised for the LH side - but working backwards /inefficiently on the RH side.
Reactions: TheSwede
TheSwede
371
211
Sweden
Update.
Now I have changed front brake pads to Ferodo DS2500, FDS1334 street/track. I suppose this will be a better solution. The old (Brembo P85159) got worse :).
The cable is just one singel cable, I have cut it off. VAG always work with two cables, so I solered a jumper cable plus heat shrink tube to the connector.
Reactions: Syphon
tracktoy
812
661
I have a different brake setup to you (I have alcon 380 x 32 mm disk running DS2500) and they work very well on the track (I do at least one a month) but I end up changing them a lot, I have been speaking with https://www.akstuning.co.uk/shop/ and next time I am going to try some other pads to try and get a bit more longevity out of the pads.
