As promised some more pictures. So first of is the high flow pump.
this is a genuine audi vw seat etc etc part. But with extensive testing by PRE they discovered the different flow rates form loads and loads of oil pumps.
I can't remember the rate but it's about 25% over standard 1.8t pumps. Plus brand new strainer
As well all seen befor a new trigger wheel.
I felt best off new one with the build so new wheel and screws.
And last of all is the ARP head stud conversion. I will show pics of the studs when I open the packet in the next couple of weeks.
Again I can't thank PRE enough for their help and advise. I know they will advise cos I am buying products from them. But the boys and girls have gone beyond just your normal help and advise. If you ever need any thing for your vag car just give them a call. They are more helpful and pleasant than the ?
Reactions: VT86 and MoToJoJo
Also some more parts to go in to the stash of goodies..
High flow oil squirters, also they are designed for the stroker set up so they miss the corroded.
Also a high flow waterpump. With metal blades. The compersite versions can expand and come off the shaft causing lack of water flow.
A gates blue kevlar cam belt
And then the start of a loads of building oils and stuff
Another delivery from prorace engineering today.
Ooooo 2 boxes inside .
Inside the first box. As the label says
Is a big turbo. A garett g30-770
Lovely casting and machining . Attention to Details like oil feed and water cooling. Etc. .
In the other box.
The hot side turbine housing
Quite heavy but all v bands and ready to be put together . More parts on the way. But Christmas is comming so hopefully a bit of time off work so I can do a but and share with you all.
Now thinking of sending off the hot side housing and a manifold when I find one I want to get zirotec ( think its called that )coated to stop heat from escaping .
What manifolds do people recommend. And not recommend. What horror stories has there been
Zircotec is a good call if funds permit it and seeing as this is a race car it'll be under continuous load so its going to do its job.
Nortech is the way to to go with manifolds and downpipes on G series turbos on these cars, it's what I have on mine as well.
Sent from my SM-S906B using Tapatalk
Reactions: Manic172
Whats you view on Turbo Blankets, do you think they are worth fitting.
Reactions: Manic172
Thumbs up for the ceramic coating the turbo hot side and manufold, I would do it (not got a turbo worth doing it to yet)
From people I know, they say Nortech are the ones to go for (think Badger5 uses them)
Reactions: Manic172
I need to look more in to this ceramic coatings. As "zirotech" seam to have just as many really pissed off customers with a poor quality product as they do have happy ... so my look about. They can't be the only company
Reactions: MoToJoJo
Looky looky. More parts from pro race engineering.
who can guess what it might be
We have a lumpy stick for the inlet .
A not a lumpy stick for the exhaust side of things
Then the adjustable sprocket
And for those who are intrested this is the details and information of the cam shafts.
Again. All parts can be brought from pro race engineering.
As promised some more pictures. So first of is the high flow pump. View attachment 39340 this is a genuine audi vw seat etc etc part. But with extensive testing by PRE they discovered the different flow rates form loads and loads of oil pumps. I can't remember the rate but it's about 25% over standard 1.8t pumps. Plus brand new strainer
How can you order the oil pump with that higher flow rate? Does it have a specific number other then the OEM number?
If you contact Pro race engineering. They will be able to sell you one. The one I have has the audi vw markings but no actual part number. They have figured it out and know the flow rates of different OEM pumps.
Reactions: Bluepower
Evening all. I need some help.. I am looking for a few parts.
I am looking for:-
1, large port head with cam caps. Don't car if it's stripped or complete. Let me know what you got.
2, I am also looking for and AGN smooth style rocker cover .
Might be helpful if I can learn how to make a sticky thread to stay at the top then I can add and delete what.I am looking for .
Please message me with any bit you might have .
I am looking for:-
I think the Admins are the only one's who can make post sticky but you could post your wanted list here but then point to it from this post https://www.seatcupra.net/forums/forums/parts-wanted.350/
I am going to throw some bits up for sale. More than likely on ebay. I will do links to them when I do. For example.. I bought from proreace a high flow oil pump... them on having a tidy up I have a race oil pump from bar-tek. And again... over excited on ebay I bought forge baffled sump... only to find I already have one in the work shop.. so I think a little Christmas sell up stuff I not going to use
Reactions: VT86
Nice build. Ha ha im in the same boat myself. Duplicates of many parts or upgraded things like coilovers only to get another set a couple of track days later better suited. Its a slippery slope especially when alcohol & late night googling is involved
Reactions: Manic172
Make a list up mate, you never know there could be something I feel like wasting my money on
Reactions: Manic172
Baffled sump is on my list, but I think goes too expensive to buy it outside of EU
