Matrix Led Headlight Upgrade is Possible?
Nov 22, 2022
Hello everyone,
I have my22 Cupra formentor.
I want to upgrade my standart led headlights to matrix led ones.
Anyone tried it before?
Is it possible?
The headlight ECU’s are same for both?
Any need to also upgrade this ECU unit?
And, sockets are same for both headlights?
Or any other upgrade requirements?
Thank you.
Reactions: klez
klez
11
Hello everyone,
Is it possible?
Thank you.
Hi,
Did you find the Part Number for Matrix headlight?
Pepcox
27
8
Slovakia
afaik you need a seperate ecu and maybe camera module.
try translate on the german formentor site, when i was researching matrix lights I found a mention that lights units are no different! And it requires a camera/ecu. no idea if correct.
Can someone confirm this?
@dbbloke Could you please resent the source link? The link you send cant be opened from some reason.
Pepcox
27
8
Slovakia
So I tried to fit it and I run into some issues. I cant find this adaptation in the 09 BCM module:
Erweiterte_Fernlichtsteuerung
New value: AFS, FLA, Fernlicht (GLW,MDF)
Other than that I think I coded everything else I found. Specifically:
in 09 Adaptations:
Fernlicht_assistent-Menuesteuerung Fernlichtassistent
Change to "Present"
Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung
Change to "Present"
A5 module coding:
Byte15 bit 5-7 changed to AFS_coding_light_assist, Matrix beam
B4 Multifunction module coding:
I overtook from the different Formentor with factory fitted Matrix headlight.
Still not work tho. Here is a log:
Code:
Friday,01,March,2024,19:50:39:26615
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5WA 937 086 AE    HW: 5WA 937 086 L
   Component: BCM37w_M028 0175
   Serial number: BXJ53F020522940 Dataset Number: V03935364GJ 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_SK38.rod
   VCID: 1470BCE8AEFDF0DA9BB-8040 SFD
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5FG 955 113 B    HW: 5FG 955 113 B
   Component: FWISCHER_MYJT  067 0053
   Serial number: 907353F0402207404486
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 555 B    HW: 81A 955 555
   Component: G397_RLFSS     H06 0004
   Serial number: 43365081X81A955555B0
   Light switch:
   Subsystem 3 - Part No SW: 5H0 941 193 AG    HW: 5H0 941 193 AG
   Component: LiSi           H04 0513
   Serial number: TW571427042200011512
   Roof electronics control module:
   Subsystem 4 - Part No SW: 5H0 959 561 AA    HW: 5H0 959 561 AA
   Component: -VW----LINDA-  503 0822
   Serial number: MW3LND14042200011194
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GA    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000027042208490358
   Rear lid opener control module:
   Subsystem 6 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 39322852
   left tail lamp 1:
   left tail lamp 2:
   Right rear tail lamp 1:
2 Faults Found:
90638 - Databus
          U1123 00 [00101111] - Received Error Message
          [Leistungsmodul für LED-Scheinwerfer links - Fernlicht defekt]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:43
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 12.3 V
                    Outside temperature: 15.0 °C
                    Light switch position: 0
90894 - Databus
          [Leistungsmodul für LED-Scheinwerfer rechts - Fernlicht defekt]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:43
                    Engine run: OFF
                    Voltage: 12.3 V
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 5WA 907 530 Q    HW: 5WA 907 530 G
   Component: GW2020 High   756 7300
   Revision: --------    Serial number: 771049050022091 Dataset Number: V03935348MH 0004
   Coding: 0000838D0F00000000000000012303527101611B03000100030100000001010000000000000000000000000000000000
   GVL: 3D0008000208C0CC80008002C800004004004002404000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 005011
   ROD: EV_GatewMQB2020_004.rod
   VCID: 56F486E0788122CA25F-8002 SFD
   Generator:
   Component: 5-01-14-01-04
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 4629999405
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 3F0 907 155     HW: 3F0 907 155
   Component: U13  DCAC      H14 0017
   Serial number: 00000000000003297161
   Multifunction steering wheel control module:
   Subsystem 4 - Part No SW: 5FA 919 719 J    HW: 5FA 919 719 J
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440059186221277
   Steering Wheel Touch Recognition Control Module:
   Subsystem 5 - Part No SW: 5FA 959 542 C    HW: 5FA 959 542 C
   Component: KLR            089 0023
   Serial number: 3136195AA22184188703
1 Fault Found:
1049110 - Hybrid Databus
          U1534 00 [00101111] - No Communications
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:41
Address 4B: Multifunc. Module (J745)       Labels:* None
   Part No SW: 5WA 907 338 B    HW: 5WA 907 338
   Component: FCM2020 Low   014 1447
   Serial number: 046908021415026
   Coding: 00000000090007CA06000910020003070300000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 004012
   ROD: EV_MultiModulContiVW38X.rod
   VCID: 4DC6698C4D576112945-8018 SFD
7 Faults Found:
0031 - Power Output Module for LED Headlamps; Right
          U1171 00 [10001001] - No Communications
          [KN_LED_DK3_R no communication]
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:41
0023 - invalid data record
          B2005 00 [10001001] - -
          [Data set AFS not valid]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
0024 - invalid data record
          [Data set MXB not valid]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
5350720 - Left Matrix High Beam
          C1175 54 [10001001] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
5350976 - Right Matrix High Beam
          C1176 54 [10001001] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
0032 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
13705487 - Databus
          U1121 00 [10001001] - Missing Message
          [Daempfer_03 data bus missing message]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:39
End----------(Elapsed Time: 01:40, VBatt start/end: 12.3V/12.2V)-----------
Still needs to upload the dataset file but any ideas what am I missing in coding/adaptation? Thanks a lot!
in 09 Adaptations:
Change to "Present"
Change to "Present"
A5 module coding:
Code:
   Light switch:
   left tail lamp 1:
   left tail lamp 2:
2 Faults Found:
90638 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:43
                    Engine run: OFF
                    Voltage: 12.3 V
90894 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:43
                    Engine run: OFF
                    Voltage: 12.3 V
   Generator:
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:41
7 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:41
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
0032 - Headlight
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:38
13705487 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 34291 km
                    Date: 2024.03.01
                    Time: 19:48:39
Did you install new headlights? You're wasting your time otherwise.
Pepcox
27
8
Slovakia
|I just need to know where I can deactivate the old light assist in 09 which was there before, because it seems that it is conflicting somehow with this new matrix one. I guess that this is also the reason why gateway getting this "1049110 - Hybrid Databus" error. I do have a VCDS orig adapter and clone for ODIS.
Update: In the meantime I uploaded the dataset file and the error for missing dataset in B4 module disappeared. But I still cant run basic settings. My guess that the reason is the same as I describe above. What do you think ?
Pepcox
27
8
Slovakia
OK I think I found the adaptation for changing the headlight units to have it handled by external 4B module. Unfortunately I'm not able to adapt it. Getting "out of range" error even though SFD is unlocked. Any help? Im not able to change value for those:
ENG172886-MAS10514-lcm-Expanded high beam control,High beam assistant ,4
ENG172886-ENG142034-lcm-Light_Control_Module,direkt verbaut ,4
@East Yorkshire Retrofits
I noticed your post in different forum out there in a thread with exactly the same issue as I have now. Do you know why I cant change those values? Thanks!
Pepcox
27
8
Slovakia
Well this is already done. I got stuck not being able to change adaptation in 09 BCM module. Even though the SFD is unlocked. Does anyone has a clue why so?
Delanor
56
10
If its any help my VZN with Matrix headlights had to have a headlight software update and the dealer struggled with the update as the car wouldn`t accept it they initially struggled even with advice from contacting the factory, it took a couple of days but it was then successfully completed.
Feb 22, 2022
86
38
guys, I have a full Formentor plugin 245cv but without the Matrix (they weren't yet available when I ordered it) and the new assisted overtaking function that was added on the my23 with the same set-up as mine;
Could you provide a list of everything I need to retrofit the Matrix? surely we need odis since the simple obd11 cannot be enough?!
yorkshire, what should I join to get you to update my control units remotely (both for Matrix and for the new assisted overtaking function)?
