Sep 13, 2020
20
Hi.
On Erwin I can find the overview of all the times my car has been at the dealer, but I get no checkboxes to mark so I can see details.
Is downloading the detailed service records locked behind paying? It's not obvious if paying will unlock details, or if only the original dealer can access their own records.
Hi.
Only the garage that posted the entry can see the details, or Seat themselves can see them all. You may be able to view more information using Seat Connect, the other brands have service info so I'd assume that Seat will too
Build info has only been removed for retail users
Reactions: Syphon and Tell
you can, say out loud, register with Erwin as a company, which is not checked, and you see a lot more ?
Can I see details for what has been done and print them? At least without the subscription, I can't print anything or see the details.
A flat rate is not required to access the digital history. What you see, is all that's available to see
If you need more detail then request the history from a dealer, or see if it's available in the Seat Connect app
Reactions: Sunsetter and Tell
I just registered on erwin. Logged in but can't see the service history. Can someone please point me in the right direction
Is this the one were you have to register as a pretend dealer which @cairus said you can do, since they don't check or I might have remembered it incorrectly. I've never seen mine but I've never really looked hard and register just as a normal user. Might be your user profile ?. It has changed since I last logged in.
Reactions: cairus
