SOS and popping sounds
Deleted member 123864
Is there a difference between the Irish and UK mobile system/frequencies? It's the only answer I can think of as I live in a rural area and only hear the popping when I enter urban areas with a 5G signal present.
Can confirm that it also happens in Scotland.
Ireland and the UK both use 700MHz and 3.6GHz for 5G.
oldgitdave
507
244
UK
Just to add to the confusion, I live in a fairly rural area and we have a 5g mast not too far away. I don't get any speaker pops or SOS notifications at all doing local driving. If I go to the Birmingham area (Cannock) or near Manchester airport I get both problems every single time.
Tell
It's the telematics unit. I recall they need to be changed where there is an issue / updated. Effected the whole VAG range but they have weeded the fix into the product range but I guess if it's doing it, it's not been fixed. Either a firmware updated or the telematics unit replaced. The mib3 firmware and the telematics unit have to be on the relevant update for all to be good. Throw this one to @East Yorkshire Retrofits . I recall it was they that said, it's your telematics unit when it came up before. Firmware on these cars is like a pack of cards if all the updates aren't right.
Reactions: oldgitdave
oldgitdave
507
244
UK
That makes sense. Mine didn't do this when the dealer updated it to 1890. They then updated to 1899 and it started doing it again (plus loads of other issues I didn't have on 1890). Now on 1940, everything is great apart from the speaker pops & SOS!
Sure we know what the fix is, that's been known for months. Why does it only happen in the UK though?
Tell
Feel free to look through the incident log of the Spanish Club Seat Leon 4 incident log. Chrome and translate toggled. I suspect you'll find it on there somewhere. There is a campaign thread
The moderator on that site is quite hot on things.
If UK cars get more issues than abroad, it will be the dealer network not getting on with these "campaigns". People on long service intervals may miss out.
Needs someone with commitment and the affected cars. I haven't got the car but sniffing around the Club Seat Leon Spanish board may be useful.
Ireland ?. Always a good test.
You missed my post from yesterday then. I am Irish, it has never happened in over 50 thousand kilometres of driving in Ireland. Since I crossed the border into NI yesterday and then across to Scotland it hasn't stopped happening.
Reactions: Tell
Tell
Life. You havent' got much 4G in Eire. I know that from my travels it drops off outside towns. Suspect it's the saturation levels play havoc with the telematic boxes. Why people say it's the same stretch of road. They do change those boxes to fix as I recall. I'm waiting for mib5 😂. 2030. Unfortunately with connected cars those that change their car regularly have to put up with these gremlins. The MQB Evo platform hadn't turned out to be the greatest whilst mib3 was a complete re-write in that Automobile Linux standard. Combine the two and treating the car as some updateable device rather than a car with stable software gives the problems. The VAG group did make the chief exec walk the plank. Good trusty dealers that know their stuff of matching firmware releases in component parts of the car has a bearing why some people get issues and others don't. Gone are the days of just mechanics and big ends 😂.
EVangelist
28
I'm in Ireland, and getting speaker pops & reboots regularly (Laois - Dublin axis & surrounding counties mostly). I visit a place very close to a communications mast regularly, and I get the pop & reboot there almost every time.
Software is 1896, but considering update to 1940.
I've only had one issue with the SOS module - the SOS and other systems (lane-keeping, ACC, multimedia) were offline for a couple of short journeys following an offline map update 2 weeks ago, but when they came back they remained stable.
I eventually pulled out the USB drive as the multimedia system kept freezing during journeys - is this because the system is slow at reading large drives?
I also have persistent dialogs coming up saying something about resetting system settings - I've been dismissing these ('Cancel') because after a previous map update, I got the same dialog and when I selected 'OK' it started to reposition the driver's seat while I was driving! Give me back a manually adjusted seat any time.
EDIT: I tapped 'OK' to the Change System Settings dialog - this time it put the car into Sport mode, but it waited until I was switching the car off to adjust the driver's seat :)
oldgitdave
507
244
UK
I've read that SOS & speaker pops need the telematics to be updated or replaced to fix it. Mines on 1940 and I still get them.
Having said that, 1940 has been rock solid for me since the upgrade in early July. It's totally cured the 'changing system settings' pop up.
Jackm44
9
Has there ever been a solution to this problem?
Purchased the 21 plate Cupra Leon eHybrid in February 2025. Experienced the popping sounds and the infotainment system getting stuck on loading screen along with the SOS error. Took it to Cupra and they said it needed big software update. Drove away and happened again as soon as I connected my phone and went onto my user profile. The SOS on the roof also flashes red sometimes.
Will be taking it back in once a part arrives for a separate issue (fuel pressure pump which was causing engine rattle and buzzing).
Thanks!
Shaun123
146
56
Yes, I have a 2021 and had the sos software updated to the telematics module and not an issue since if they update the infotainment only the sos will still carry on giving you issues. You need to push them to update that module
Jackm44
9
That seems to be the common thing that everyone is saying regarding the SOS module. So even if the infotainment system is updated without the SOS, does this still cause the popping sounds?
I'll be mentioning this to them when it's back. Thanks for the response.
Shaun123
146
56
Yep, infotainment update has no impact on the sos module as those are different updates. I had the sos update but had to really push the dealer to do it.
they know about it but don’t really like to do the update.
some updates don’t work and have to replace the sos module.
But there is a fix as had mine done about 2yrs ago and been fine since
Reactions: Tell
