Oct 31, 2022
9
Hi,
For an 2017 Ibiza, is it possible to replace the standard media system (as shown below) with the satnav media system (Part No.: 6F0919605A) as a straight swap, or would additional cabling, sensor, etc be missing and therefore need to be installed?
Standard media system pic:
SatNav Media System (6F0919605A) pic:
You have to change the glove box, yours doesn't have a slot for the box with CD and 2 cards that you also have to buy, a screen as you have in the photo, the two cables that connect to the screen and the box in the glove box.
Okay, got it - thanks! It's pretty much the same setup as a Leon with satnav head unit and CD player inside the glove box. The CD player has two SD car slots, one which is used for the satnav maps. Hopefully I can get the satnav head unit, CD player and cables from someone who's broken up a written off Ibiza with the relevant kit.
Thanks for your helpful reply.
Trying to do the same thing on my 2018 Ibiza. No dealers or audio shops want to help at all in Sweden so looking at buying the parts myself.
Figured out the stuff I need...
6F0919605 (A?) display
5QA035846, 5QA035846 (B?) glovebox unit
and pretty sure I need to upgrade the usb port with 5Q0035726
I'm planning on cutting a hole in the glovebox to make the navigation unit fit, not too bothered about how it looks in there.
Problem is when swapping to new units I guess there is some kind of coding needed to be done to unlock it and pair it with your vehicle. How did you guys sort this out.
Very grateful for any help or advice. ?
You can do it in 2 ways
you assemble everything and take it to the dealer to unlock and enter all the settings for your car
Mount all acquires software on the VW website, but I think a specific program is needed to download it online
I don't recommend cutting the glove compartment, it will never be secure, it will wobble but that's my opinion.
Be careful, one of the cables that connects to the screen is very difficult to find
Reactions: timmothee
Hi Jose I’m confused on which key to buy? I have a 2017 model any help would be appreciated
I bought everything needed for this project for my Ibiza and then switched to a León before I found time to do attempt the switch. So, i have everything here that I don't need anymore, it is ready to post to someone if they give me a reasonable offer for it.
How much do you want for this ?
Ok, again some questions:)
- are you prepared to send it to the Netherlands
- do you have some pictures from the set
- are you convinced that it works
