May 4, 2025
Can someone help? With the new one Relay 409 and the old one is same. When I drive at a certain interval this lights up and the car stalls for a second or so but it doesn't do it every day I changed the relay but there is no progress, I also cleaned the throttle valve. And the same thing again.This is the video
I would pull the relay out and check for corrosion in the socket, if the socket is ok then check for loose connections behind the panel. Disconnect the battery while checking behind the relay panel as you do not want to be creating a short circuit by accident. Those terminals carry a lot of power.
I checked every relay is okay , it’s only sometimes when make it and maybe like intervals around like 5 seconds
