Connor H
1,052
518
Essex
clutch pedal broke again. Bloody cursed this car is , i blame whoever dug up my old thread recently, jinxed me!
mty12345
4,117
681
bristol
whats worse is this is a replacement pedal already, needs welding cos the sh*t it left me in yesterday was brutal
ill be back for some bits soon though
I epoxyed mine along the joints, not sure if it will make a diference but didn't have opportunity to weld it at the time
Reactions: Connor H
jlv81
106
103
South Yorkshire
So my clutch pedal didn't come all the way back up on my way home this morning. When I got home I pulled it up, and it seems fine. Is this a common issue? Also, its pulling to the left, even after I got the tracking done 3 weeks ago. Any ideas what could be causing this?
Connor H
1,052
518
Essex
ive had loads of clutch issues
pedal pressure could be
air in the system - needs bleeding - check for leaks - lines and brake bleeder block
brake fluid low - check the system for leaks
slave cylinder on its way out (6 speeds is inside the gearbox)
master cylinder(by clutch pedal) could be on its way out or leaking
clutch release bearing might be shot (inside gearbox)
start with checking fluid and maybe bleeding the clutch line
Connor H
1,052
518
Essex
What happened to it? Did it snap? I was driving home this morning and my clutch pedal wouldn't come all the way back up, should I be worried?
yeah theres a design fault and small piece of metal snaps leaving you stranded. The pedal needs a few welds and will be fine.
iammooks
1,827
1,228
I'm going to have to buy a new clutch pedal and get it welded just in case.
Where are you all getting them from?
mty12345
4,117
681
bristol
I got mine from there, but if you're going to weld it then you could just get a secondhand one from Thai
mty12345
4,117
681
bristol
It was the slave cylinder in the gearbox when that starting happening to mine, but as Connor said it could be other things too.
mty12345
4,117
681
bristol
Any ideas on the cost of fixing any of these issues
Slave cylinder is only about £40, main cost is removing and refitting the gearbox. Probably 3 hours labour. If you have to do it then it may be worth replacing the clutch while you're in there.
jlv81
106
103
South Yorkshire
Yeah, 8 most probably would do. Any uprated clutches that are good and cheap? And any other modifications I could do while it's being changed?
Lockee
51
16
Going through it lads... Have the dreaded lean code, boosting all kinds of jumpy, and need to get the emissions down for the NCT👎 have changed the n75 no change, ordered a boost leak test kit, can't get a mechanic for over a month...
Was going to just reorder the pcv system and replace the parts but the cars modded and theres a n249 and pcv delete on it. Can't tell what I should be doing or looking for as all the videos and tutorials are for stock or different to what I have going on 😅
Anyones guidance or encouragement is welcome😂
Connor H
1,052
518
Essex
Do you have a boost gauge? you could probably tell if you have a boost/vac leak there first
People do weird stuff to the PCV system, you really cant go wrong with the standard setup. you might try getting a cheap PCV pipe kit for that.
lean can be a few things, you could even have poor fuel pressure. What codes do you have?
Lockee
51
16
Yeah have the boost gauge. Seems to be jittering when idle, boosts sometimes holds at 10psi then will hold at 15psi then other times shoots to 20psi. So from my research that means n75/vac lines/PCV.
Going to service the recirc valve replace the lines.
Was going to just put in a catch can for the pcv.
From what I can see these mods were done car was mapped for them
P0171 code on the basic obd scanner.
Just had it in the garage for the manifold gasket thought that was the issue but no better performance just less tractor like now
Sent from my 2312DRA50G using Tapatalk
jlv81
106
103
South Yorkshire
Hope it's an easy fix
